Old 21-09-06, 02:41 AM   #1
wmrra#30
Default Swap Old Engine into Newer SV?
Has anyone here had experience with swapping an older lump ('99 - '02) into the newer chassis ('03 - '06) SV650?
Racing this year I’ve blown two newer style motors (snapped crankshafts, ruined engine cases, etc.) and I want to be sure the older style engine will fit if I happen to come across a good one. Been told the older cranks and engine cases are stronger.
By searching this site I found one post indicating that to fit a newer lump into the old chassis you would use the following parts from the old lump to make the new one work with the carbs.
Generator and rotor (different size)
Gear-position indicator (Reads every gear for injection)
inlet rubbers (different size and angle)
Thermostat housing (temp sender is different)
Assume the opposite would be true to get the old motor to work with the fuel injection. I’ll also be swapping in the cams, pistons, cylinders, heads, etc. from my old race motor.
Any thoughts greatly appreciated.
Old 21-09-06, 07:55 AM   #2
TSM
The Sick Man
TSM's Avatar
If you just put in a CDI & loom from a 1st gen bike then it should work easier.
Old 21-09-06, 08:00 AM   #3
Viney
Wont the crank fit from the earlier engine?
As for engine casings. Get some armour www.bikejohnny.com
Old 21-09-06, 08:02 AM   #4
Mike1234
Default Re: Swap Old Engine into Newer SV?
Haven't tried it that way round but have put fuel injected engines in to the old frame. The only thing we changed were the inlet rubbers and the generator and rotor (including the engine casing on that side). Everything else just worked.
Would suggest you keep the barrels, cylinders, etc. as they are and just swap the cams, tensioners and buckets. Anything else is a waste. Alternatively just get a K5 fuel injected motor as I have yet to hear of one breaking a crank which seems to happen most frequently in the K3 motor.
Old 21-09-06, 08:05 AM   #5
Mike1234
It's not that they are a different size it's that the fuel injected bike has loads of pick ups on the fly wheel where as the easrly motors only had one.
Old 21-09-06, 11:10 AM   #6
Out of curiosity, what have you got on top of that bottom end?
Engine Swap lazymanc SV Talk, Tuning & Tweaking 18 25-04-11 11:15 AM
Engine swap advice sixstring SV Talk, Tuning & Tweaking 7 18-01-08 09:44 PM
engine swap this weekend (hopefully all done on sat) fat_brstd Thames Valley 17 23-09-07 09:02 PM
SV650S engine swap LeeSV SV Talk, Tuning & Tweaking 7 26-02-07 08:33 PM
sv650 engine swap toyotafj40s SV Talk, Tuning & Tweaking 5 24-08-06 08:54 PM
