Old 23-09-06, 08:06 AM   #1
Tigerrrr.......
Default Stebel Magnum horn - fitting
Just bought a Stebel Magnum horn (Halfords - £13.95) for my K3 S pointy.
Any top tips on fitting? It looks fairly straight forward, although I may need a longer fitting bracket.
Any advice much appreciated.
Cheers.
Be safe, be seen.
Tigerrrr....... is offline   Reply With Quote
Old 23-09-06, 08:23 PM   #2
It might need a relay to run right... I had a Stobel Nautilus briefly before I got the FIAMMs, and none were happy with the stock wiring- the FIAMMS just click while the Stobel ran at very low power.
Old 23-09-06, 08:44 PM   #3
SVeeedy Gonzales
I mounted mine on my K4 using the stuff in the pack, off of one of the bolts on the left side of the radiator (pretty close to the original horn so the extra wiring was easy and the original is still there and easy to go back to if need be). Works fine straight off the battery and takes minutes to fit that way. Need to position it with the horn facing down to stop muck collecting in the horn. It's a bit louder, though not as loud as I'd like.
Old 23-09-06, 09:45 PM   #4
dirtydog
Knob faced knobster
dirtydog's Avatar
fitted mine on the radiator on the left hand side on the lower screw for the rad cover used it with the standard wires with no problems
2001 SV650 in shimmerin green, Not broken anymore
Stebel Nautilus air horn SOLD Nobbylad For Sale - SV's and SV related items 4 19-02-09 11:44 PM
Stebel Magnum Horn Stradders SV Talk, Tuning & Tweaking 5 20-10-08 07:49 AM
stebel magnum ? hovis SV Talk, Tuning & Tweaking 37 22-06-07 09:46 AM
Stebel Magnum horn bendelfont SV Talk, Tuning & Tweaking 5 11-07-05 09:08 PM
Stebel Nautilus Horn philthunder Ancillaries 2 06-03-05 09:57 AM
