Old 03-10-06, 04:08 PM   #1
brenthilg
Default Do I need a new clutch?
Here'e the deal. I was doing a burnout for the first time on my bike because I was getting a new tire, so I figured I might as well have some fun. But now my clutch is slipping very bad. Like a gentle rev on the throttle will cause it to slip. Has something come loose, or have I somehow burned out my plates? I don't want to have to replace the plates if it's not necessary. I have an 05 sv650s with 13k miles on it.
Old 03-10-06, 04:16 PM   #2
Carsick
go to this thread and try Sid Squid's advice on adjusting the clutch first. If that doesn't work, then maybe you do need a new one.
Old 03-10-06, 04:18 PM   #3
Stu
Trinity
Stu's Avatar
Getting new tyres at the weekend - was probably going to do something similar - you've put me off
Old 03-10-06, 05:11 PM   #4
brenthilg
Tried that, and all seems to be in order. Also, excuse the newbie question, but is there transmission fluid in the engine, or just oil? I could maybe try replacing the transmission fluid too if it exists. And if it does, where do I fill it, where do I empty it, and how do I gauge how mush is in there? Thanks
Old 03-10-06, 06:02 PM   #5
andyaikido
Engine oil does it all in bikes (unless you have a dry clutch).
By all in order you mean it's working now? Or it's adjusted and still slipping?
Not put fully synthetic oil in it, have you? Shouldn't slip that badly though even if you had.
Old 03-10-06, 06:08 PM   #6
brenthilg
Sorry for not being very clear.... It is adjusted correctly and it is still slipping. I have never used synthetic in the bike, only the local dealer's recommendation (Honda GN4 oil).
Old 03-10-06, 07:14 PM   #7
brenthilg
I think I'm ready to take the thing apart and look at the plates. I'm assuming there is a gasket that I will need to replace once I take the side of the engine off. Anyone know where I can get this gasket?
Old 03-10-06, 07:54 PM   #8
Richie
fantabulas
Richie's Avatar
local suzuki dealer,
6 quid.
My Flickr photos
Old 03-10-06, 08:00 PM   #9
jambo
jambo's Avatar
Bad news is on the K5 you'll need to drain the coolant and take the right hand engine cover off to check it.
Old 04-10-06, 01:02 AM   #10
Warren
you back hall13uk ?
this time, dont get charged a tenner for a washer
sorry, couldnt resist
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
clutch kit sv650nutter149 For Sale - SV's and SV related items 0 25-06-07 03:08 PM
clutch has had it! socommk23 SV Talk, Tuning & Tweaking 8 10-03-06 06:21 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
