Old 08-10-06, 11:52 PM   #1
5hort5
Default Rear brake caliper stuck
How do I unstick these things without geting out the WD40
5hort5 is offline   Reply With Quote
Old 09-10-06, 07:23 AM   #2
Viney
Take it off, strip it down, clean and re-build with new pistons/seals/pins.
Job done
Old 09-10-06, 04:57 PM   #3
Mesomorphman
How'd they get stuck? Just curious.
Old 09-10-06, 05:48 PM   #4
BILLY
All the brake pad dust and road crap!!! Before striping try giving it a good blast with brake cleaner and a scrub with a tooth brush!!
Old 09-10-06, 07:50 PM   #5
Scoobs
Job done
The cost of these parts is stoopid. I always found it was cheaper to get a caliper from a breakers.
Old 09-10-06, 08:29 PM   #6
BILLY
The last seal kit I bought cost me about £18 and I cleaned the pistons up with no probs!!!
Old 09-10-06, 08:41 PM   #7
instigator
I've yet to find a knackered piston seal in all the brake calipers I've had apart. Dust seals, certainly, any break in the two ridges and they need replacing but they're not that expensive. Usually get them from wemoto or something similar.
Very easy to do.
Old 09-10-06, 09:39 PM   #8
I replaced the caliper when mine spar a seal... £10, came with stainless bleed nipples, a decent set of pads and a GSXR SRAD torque arm.
Old 09-10-06, 10:13 PM   #9
svrash
Have you tried removing the pads and pins, pumping the pistons out a bit and having a go with brake fluid/brake cleaner and a tooth brush?
If so, seal kits aren't that expensive but i would recommend changing bleed nipples, brake pins and bolts for stainless steel ones, most of my stuff came new from ebay
then i would find a SRAD torque arm as northy suggested, its a shame to ruin a nice shinny caliper by using that nasty, rusty SV one
P.S. the bolts that hold the caliper together are M10 fine pitch ones, don't get caught out by thinking there standard pitch like i did and don't forget to give the pistons a coat of red rubber grease to prevent future seizures
Where can I buy SS Rear Brake Caliper Pin ? leegriffiths128 SV Talk, Tuning & Tweaking 4 22-08-08 02:19 PM
Rear brake caliper Baz SV Talk, Tuning & Tweaking 4 05-08-08 05:14 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Rear Brake Caliper Cam_73 SV Talk, Tuning & Tweaking 10 03-02-08 03:36 PM
Rear brake caliper madderdog SV Talk, Tuning & Tweaking 9 15-12-07 01:30 PM
