Old 09-10-06, 08:04 AM   #1
hovis
Default sv plug spanner
the pointy plug spanner the same as the curvy plug spanner ?
my lowers are coming off, do i need to take off top fairing to get to front plug?
Old 09-10-06, 08:09 AM   #2
Viney
Default Re: sv plug spanner
No just the radiator!!
If its your first time, then be prepared, its not the easiest of plug changes. You can force the rad out of the way, but be careful not to split the hoses.
Old 09-10-06, 08:09 AM   #3
SpankyHam
Yes you are talking about the spark plugs right ?
They're the same size.
You just have to undo the bottom Rad Screw & the side screws of the fairings so you can pop the radiator out & push all the way forward. (Make sure you remove the horn as well)
YOu should then be fine accessing the front Spark Plug.
Old 09-10-06, 08:58 AM   #4
600+
The guy that designed the bike and positioned the front plug there needs shooting!
Old 09-10-06, 09:21 AM   #5
cyphertheory
mind you where else was he gonna put it? lol
Spark plug spanner for Curvy needed - Bracknell Colby Guildford Massive 30 28-04-08 02:15 PM
Spark plug spanner for Curvy needed - Bracknell Colby Thames Valley 3 24-04-08 01:04 PM
Spanner Man plowsie Idle Banter 4 06-09-07 03:19 PM
Anyone near Ely know how to use a spanner? New Leaf East Anglian Revolution 6 24-06-07 03:44 PM
Plug spanner size? triumph5ta SV Talk, Tuning & Tweaking 10 01-02-06 11:57 PM
