Old 18-10-06, 05:07 PM   #1
Saucerboy
Default How bad is it?
First off, hello to all you fellow SV owners & lovers.
Right, I've just been cleaning up my bike (2000 SV650S) and found a worrying crack where the radiator mounts onto the engine block. How bad is this and how much do you think it'll cost to repair?
Cheers,
Saucerboy
Old 18-10-06, 05:10 PM   #2
hovis
First off, hello to you too
but your link donk work
depends how bad it is,you could get it welded £30
Old 18-10-06, 05:12 PM   #3
Saucerboy
Hi!
Sorry, hopefully it's working for you now
Old 18-10-06, 05:15 PM   #4
hovis
yes
looks like its the rad bracket???? is it?
you could get this welded £30 tops IMO
Old 18-10-06, 05:17 PM   #5
hovis
Originally Posted by hovi5
yes
radiator £100 new......£60 used £20 to weld....again IMO only
Old 18-10-06, 05:20 PM   #6
embee
embee's Avatar
Just had a look at mine, and it's really only a steady for the bottom of the rad.
Either someone has been over-enthusiastic about tightening it, or possibly it's a result of a minor drop.
In all seriousness if it was mine I'd remove the bolt, clean and ease the crack using a hacksaw, and fill it with epoxy (Araldite). When set (24hrs), run a drill through the hole if necessary to clean out any epoxy, and be gentle tightening the bolt. A spot of black paint and you'd never know.
If worried otherwise, simply pick up a replacement cam cover.
Old 18-10-06, 05:23 PM   #7
hovis
yep, good idea no point buying a rad............do as above or get it welded
Old 18-10-06, 05:33 PM   #8
vulcan666
It's intuitive to think "If tight is good, tighter is better" but it's wrong. Another good argument for using a torque wrench. Otherwise we tend to overtorque small bolts, and undertorque things like the rear axle nut.
Old 18-10-06, 06:18 PM   #9
sdusk
Not sure about the curvy, but on the pointy there should not be a nut on the end of that bolt, as it is a threaded hole. Looks like someone broke it long ago...I wouldn't be too worried.
Old 18-10-06, 07:09 PM   #10
I've probably got a cam cover that colour in the Heap'O'SV... Not 100% but I think so.
Does the rear cover have the same casting? If so, just swap 'em, job done. Dead, dead easy too.
