Old 23-10-06, 06:13 PM   #1
01 sv650s
Default tank spacers
do tank spacers do anything. if i fitted them to my curvy would i notice any difference. thanks
Old 23-10-06, 06:24 PM   #2
jimmybluedevil
Its one of the things at the top of my future mod list. Ive heard that spacers make a huge difference in performance but Im not sure if the increased air-flow would lean the mix out too much.
Old 23-10-06, 06:27 PM   #3
r4ce_e3nd
you will feel something but don't expect much dho...
but it is a cheap mod and easy to do, so why not?
Old 23-10-06, 08:16 PM   #4
instigator
Make them yourself. I plan to.
Old 23-10-06, 09:25 PM   #5
If you're rejetting/mapping anyway, then yep. On mine it was worth one extra jet size up top. Not sure what that would equate to in power terms, not very much, but it'd be daft not to take advantage unless you have an aesthetic objection (it does look a little ugly)
Old 23-10-06, 09:34 PM   #6
svrash
I've got some 25mm diamiter black nylon bar that i'm making some 25mm spacers out of...for £3 i can do you a pair PM me if your interested
Old 23-10-06, 10:28 PM   #7
I got Chewy's, because they're purty. Doorstops would work
Old 23-10-06, 10:31 PM   #8
r4ce_e3nd
I've got a pair of aluminium made on a turning late
hight: 10mm
Old 23-10-06, 10:37 PM   #9
Demonz
I used some brass plumbing washers from homebase and with some longer bolts. A*se dyno didnt show any improvements - and I am truly doubtful of any performance at all from it. My big benefit was my legs actually fitted under the tank better - it lifted it just enough to get a knee in the groove - made hanging on around corners easier.
Old 23-10-06, 10:57 PM   #10
Razor
Forget performance, makes a better induction noise
Swap - Chewy`s Tank Spacers xXBADGERXx For Sale - SV's and SV related items 6 10-07-08 04:43 PM
Tank spacers - advice req'd netsurfer SV Talk, Tuning & Tweaking 15 06-01-07 03:58 PM
Need some spacers made. Razor Bikes - Talk & Issues 3 11-06-06 09:27 PM
Curvy's+Tank Spacers+Cool/Damp Weather = Ropey Running Dan_SV SV Talk, Tuning & Tweaking 3 19-04-05 03:07 PM
Air supply :: Tank spacers :: Other methods snoopy SV Talk, Tuning & Tweaking 38 07-01-05 06:38 PM
