Old 25-10-06, 09:37 AM   #1
james160987
Default l.e.d indys
What are you guys using to slow the flash rate down, a different relay or inline resistors, if the resistors what ones do you use?
Old 25-10-06, 11:04 AM   #2
mattSV
mattSV's Avatar
10 watt 10 ohm resistors - about 40p each from Maplins
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 25-10-06, 11:36 AM   #3
Viney
...wired in parallel with the indicators
Old 25-10-06, 12:16 PM   #4
james160987
my front led indys , the ones from canada. http://www.watsendesign.com/Suzuki_P...V_Products.htm
came with 10 watt, 4.3 restistors, so i just got the closest to them which is 4.7 gonna give them ago,
they slowed the front down, but when i changed the back toi l.e.d aswell they sped up again
Old 25-10-06, 01:30 PM   #5
jambo
jambo's Avatar
You will need to add a set on resisters in parallel to the rear bulbs as well then, as it's total resistance of the system, that is both bulbs. Changing each one will alter the values. Alternatively just using 1 set of 10 Ohm resisters (either front or read) instead of 2 sets of 4.7 Ohm resistors (Back & rear) should work
Old 25-10-06, 01:34 PM   #6
james160987
ive got 4.7 for the rear and 4.3 at the front, im guessing this should be ok?
Old 25-10-06, 01:41 PM   #7
jambo
jambo's Avatar
Only way to tell is to fit them, or actually do some maths. But doesn't sound too far off to me.
Old 25-10-06, 02:12 PM   #8
Baph
If the 4.3Ohm resistors slow it down enough, 4.7 should work fine too. Afterall, we're only talking about 12v.
The only side effect is that it might slow them down a little more than it should. Even so, it should still be legal & MOT-able.
Old 26-10-06, 07:02 PM   #9
Horney
james160987 How you getting on with this as I have the same problem?
Old 27-10-06, 12:39 AM   #10
james160987
my mate ent wired the plugs on for me yet mate, ill let you know soon as he has,
LED indys. Rich Bikes - Talk & Issues 10 29-05-08 10:58 PM
Small problem with my built in indys sv-robo SV Talk, Tuning & Tweaking 4 14-04-08 04:36 PM
Mini Indys Mike2165 SV Talk, Tuning & Tweaking 6 10-01-08 09:29 AM
LED Indys ukhammy SV Talk, Tuning & Tweaking 1 30-12-07 05:14 PM
Short or long stem indys? TC3 SV Talk, Tuning & Tweaking 5 28-11-05 03:34 PM
