Old 26-10-06, 10:13 AM   #1
grecian9
Default investigating clutch probs - a newer stupider question.
Very very basic question here. I'm having this problem
http://forums.sv650.org/viewtopic.php?t=26137
I have a 99 curvy and want to try Sid Squid recommended fix. Is taking the black clutch cover off going to mean I have to sort the problem or is it possible to just remove for a look and replace without buying any new gaskets or other parts?
I've never done this before but wary of asking a garage to sort clutch as I'll be £80 down before they've even fitted a part!
cheers
Old 26-10-06, 10:17 AM   #2
Viney
Taking the clutch cover off is easy enough, you can remove have a look and poke around without having to do anything. Just remember to check that the gasket is in the groove properly on refitting...unlike min and it ****ed oil all over the exhaust on the way home one night
Old 27-10-06, 08:10 AM   #3
grecian9
...and when the cover is removed will oil come rushing out? (you can tell i'm a novice ). Will I need to replace any fluids? I only did a oil & filter change 3 weeks ago so reluctant to replace the oil.
Old 27-10-06, 08:56 AM   #4
jambo
jambo's Avatar
on a curvy if it's on the side stand, it will be fine. Might be best to have a little tray under the cover in case you loose a little bit of oil, but it should be ok.
Old 27-10-06, 04:40 PM   #5
egypt220
is it not a plastic cover,so wait till bike is stone cold or it may worp,dont over thighten the bolts when you put it back on
Old 30-10-06, 08:03 AM   #6
grecian9
Ok, once I realised I wasn't removing the circular clutch cover but the sprocket cover next to it I adjusted the clutch as per the method described. Got it wrong at first but second time seems to have improved things a not inconsiderable amount. I'm still getting light slippage at full throttle so I think perhaps the actual clutch will need investigating by a proper mechanic at some point.
Clutch lever question. The Guru Bikes - Talk & Issues 15 12-09-08 09:31 AM
clutch question olden mgroin SV Talk, Tuning & Tweaking 1 31-08-08 05:17 PM
sorry clutch question steveg SV Talk, Tuning & Tweaking 8 05-07-08 04:47 PM
Another clutch question Peetee650 SV Talk, Tuning & Tweaking 5 14-06-08 06:27 PM
Clutch question lukemillar SV Talk, Tuning & Tweaking 2 08-05-06 05:30 PM
