Old 02-11-06, 08:42 AM   #1
Marshall
Default Carb Icing
whats the stuff you can put in your fuel to try and stop carb icing
Marshall
Old 02-11-06, 08:52 AM   #2
andyb
I THINK its Silkolene Pro FST cant be 100% though.
Old 02-11-06, 09:20 AM   #3
mysteryjimbo
Alternatively Wynns Dry Fuel and/or premium petrol
Old 02-11-06, 09:42 AM   #4
fizzwheel
fizzwheel's Avatar
Aye thats the stuff.
I found that if I used Optimax or the BP Equivalent of it ( I cant remember what its called ) I didnt suffer from carb icing. If I use cheapo supermarket petrol then my SV suffers really bad from carb icing.
HTH
Old 02-11-06, 09:57 AM   #5
Grinch
HTH
I agree with what fizz said... the shell stuff is the best price then the BP... though I have found the Sainsburys super unleaded is the best of the super market stuff. Don't use Morrisions, there fuel seems crap, though Jet is the worst. As it seems they stick any old crap in there tanks, I had to drain a whole tank full when it screwed up Jax's Duke.
As the moment I am most using Sainsburys Unleaded, but that may change as the weather moves in. Silkolene Pro FST is good but it costs a lot and using 'super' fuels is better in the long run, though you can add the Silkolene as and when needed. So make your choice...
Old 02-11-06, 12:07 PM   #6
SV650Racer
stick normal fuel in it and then use the Pro FST as required. Great stuff! Good tip is to buy some small sample bottles that carry just the right amount for a tank full of fuel and keep them under the seat. Saves you carrying the bottle around and measuring it out everytime!
Old 02-11-06, 12:13 PM   #7
Marshall
cheers lads, I'm running the cheapo Salisbury's fuel at the mo. i might try optimax when it get a little colder
Old 02-11-06, 05:27 PM   #8
Biker Biggles
Biker Biggles's Avatar
Ah ha.That time of year again.I can feel a few threads on this coming along.
Old 02-11-06, 06:22 PM   #9
Randy O reckons that pretty much any isopropyl-based additive would do the same, I think he advocates Rebel Yell I sent him some Pro FST but I can't remember the results...
Me, I used Optimax last year, which almost-but-not-quite got rid of it, and on the occasions it didn't I'd add Pro FST. Works out much cheaper that way. The recommended mix from Silkolene is 1% normally, 2% for bad conditions- that's 160ml-320ml every time you fill up, so a bottle doesn't go far.
Old 02-11-06, 06:28 PM   #10
Razor
I could only get Wynn's dry fuel at local Halfrods. It sez a bottle per tank but that's a car so 1/4 bottle per bike tank I think...
Is this carb icing? captainsmelly SV Talk, Tuning & Tweaking 37 17-02-09 08:35 PM
Carb icing william t. SV Talk, Tuning & Tweaking 10 28-02-07 11:30 PM
Carb Icing fizzwheel SV Talk, Tuning & Tweaking 65 24-11-05 11:24 AM
Carb Icing squirrel_hunter SV Talk, Tuning & Tweaking 44 02-09-05 02:46 PM
Carb Icing: MrMessy Bikes - Talk & Issues 3 28-01-05 02:11 AM
