Old 03-11-06, 11:50 PM   #1
nigelv68
Default Softer grips !!
I want to get some soft comfy grips for my bike can anyone tell me a good make that will soften the blow and stop me getting dead hands & fingers after 20mins 0f being on the bike ?
Preferably some that have an SV 650 design would be nice, just to add a little syle as I need to change them ?
please help !!
Old 04-11-06, 12:24 AM   #2
BILLY
Before you go out and buy some more grips. Try relaxing you grip on the bars!! It worked for me!
Old 04-11-06, 02:52 AM   #3
GDBD59
If it's for the current & near-future temperatures you're meaning you'll probably need heated grips.
The combination of vibes & cold is basically "white finger". There's been plenty discussion over the years about it.......use the search engine. Having the carbs balanced can help to reduce vibes, which has been mentioned in the topic threads.
If you don't want heated, next step on the vibes insulation is foam grips.
Old 04-11-06, 09:39 AM   #4
nigelv68
Billy : thanks for that , but I am not a nervous rider. It is for me the reach and bar position that is causing the problem, ibelievee.
GDBD59: I ride an injected 05 model so I guess its not the carbs ?
I have had this problem with the bike since May this year , so its not cold related.
I understand renthal do dual compound grips anyone tried them ?
idefinitelyy need softer grips to solve the problem justdon'tt want a box full before I find the right ones ?
Old 04-11-06, 09:49 AM   #5
rictus01
rictus01's Avatar
Indeed Renthal do several grips of differing compound, a hard, medium and soft, also a duel compound.
have a look here http://www.bandcexpress.co.uk/cgi-bi...l?cat=HBA-GRIP
Just as a point, although you don't have carbs, your throttle bodies can go out of balance as well, so it wouldn't hurt to balance them anyway.
Cheers Mark.
Old 04-11-06, 09:54 AM   #6
jambo
jambo's Avatar
I would tend to go with the above advice that softer grips won't really stop your hands going numb. That said Renthal grips are supposed to be pretty soft but this is purely meant to ease a problem of fingers slipping on the grips. If your bike is a K5, then it does not have carbs, but the throttle bodies can go out of sync exactly the same way causing the engine to feel vibey and lumpy.
If you say it's the reach and bar position that is causing you this problem then the softer grips are unlikely to help a great deal. You could try fitting different bars to alter their position if you find you are putting weight through your arms and wrists.
:edit: if you type slow someone will beat you to the good advice
Old 04-11-06, 10:37 AM   #7
fizzwheel
fizzwheel's Avatar
Dont know about grips, but have you tried adjusting what you can to make the bike more comfy...
I found that rotating the break and clutch levers around so that I had a straight line from my elbow through my wrist made the bike much more comfortable to ride. Also and I don't know how long you've been riding for, but have you tried gripping the tank with your knees and relaxing your grip slightly on the bars. I found that makes a big difference as it takes weight of your wrists.
HTH.
Old 04-11-06, 07:25 PM   #8
skidmarx
Not much too add here, relax grip with knees etc. But watch out for adjusting the levers too much. It does help but I really knackered the tendons in my left wrist when I adjusted the clutch lever too far. Very slight adjustments can put a lot of strain on different parts of your hands/wrists....all ok when I put it back
Old 05-11-06, 01:02 PM   #9
thor
The oxford heated grips are softer, but they are larger too so an R6 throttle tube is a good idea while you are at it.
Old 06-11-06, 09:59 AM   #10
He did say "relax your grip" not "relax"- most hand problems are either from a bad riding position (too much weight on the hands), vibrations (TBs out of balance usually) or gripping too hard. Not all, though.
SV Gel Grips RRP £14.99 Yours for £13.00 SAMMY650 For Sale - SV's and SV related items 0 08-07-08 11:00 AM
Hot Grips metalmonkey SV Talk, Tuning & Tweaking 40 03-11-07 12:28 PM
Hot grips yorkie_chris SV Talk, Tuning & Tweaking 18 02-11-07 10:18 PM
Hot Grips andyb Bikes - Talk & Issues 21 20-09-07 02:23 PM
Softer suspension for lighter & disabled rider needed Alex Oliver SV Talk, Tuning & Tweaking 2 18-11-05 01:00 PM
