Old 05-11-06, 06:00 AM   #1
zmax650S
Default My 05 Suzuki SV 650S is at WOT when started!
WTH, just got it out of storage, went to start it, all was well, then after 5 minutes of idle, the FI light came on, then about 5 minutes later, the RPM's go all the way like it is WOT but the throttle linkage is not broken, everything works fine.
Could it be bad injectors since the bike sat for 6 months? Any tips, warranty ran out last month, so go figure? I disconnected the battery, changed the oil, filled it with Super unleaded, and added fuel stabalizer when I put it in storage.
This blows! Oh and my warranty went out exactly one month ago, dam! Bike has 950 miles!
Old 05-11-06, 06:14 AM   #2
philipMac
Not trying to be thick here, but what's WOT?
You can try sticking it in Dealer Mode, and this might tell you more definately what the story is...
http://forums.sv650.org/viewtopic.php?t=10245
(It could very well be clogged injectors if you left it for 6 months though...)
Old 05-11-06, 06:22 AM   #3
zmax650S
Wide Open throttle. Wonder what a typical repair shop will charge?
Old 05-11-06, 07:00 AM   #4
philipMac
No idea really without knowing what the problem is.
Try that dealer mode thing for starters.
Old 05-11-06, 10:35 AM   #5
independentphoto
Hi there,
I'm not sure about Wide Open, but my K5 has had the FI light come on a couple of times and each time, when I've pulled up the revs have been way up at 3-4k. Switch off and sit a minute and then your off again with everything back to normal. The dealer looked at it and put it down to a sticking throttle cable. That was a while back when the bike was very new and it's not happened since.
Maybe since you're only at 950 miles and it's been laid up, the cable has got a bit dry and sticky. I'd look there and check both cable adjusters are set properly.
Good Luck,
Cheers,
Garry
Old 06-11-06, 02:08 PM   #6
sixstring
My Vauxhall Vectra used to do that I'm not sure if it's relevant but it was the throttle position sensor at fault. Try giving it a good clean with some carb cleaner. worked a treat on my car
Old 08-11-06, 07:47 AM   #7
zmax650S
Thanks guys, looks like I will just drop it off to the dealer, and just suck up the bill this time. I just won't have the time when I return from Korea in Mar 07 to troubleshoot/diagnose the issue. I am new to bikes. I have to move stuff including my 350 ZR out of storage and the ZR is more important when I return. Plus I have some mods to install on the ZR (exhaust, tailight upgrades, CAI, wheels, ect)
Hopefully they won't stick it too me on BS labor charges.
Thanks again guys!
Old 29-04-07, 09:22 PM   #8
b1kerb0y
Default Re: My 05 Suzuki SV 650S is at WOT when started!
im guessin its a pointy. if so they av an auto choke so that could be broken which can cause the revs 2 go higher than normal
Suzuki SV 650s Road/club racing Project. John 675 SV Talk, Tuning & Tweaking 55 09-02-09 11:23 AM
2001 Suzuki SV 650s for sale (Ireland) Graham K For Sale - SV's and SV related items 1 05-10-06 06:57 AM
SUZUKI SV650S SV 650S 2003-2006 LED INDICATOR SIGNAL Diveboy For Sale - SV's and SV related items 4 27-06-06 04:33 PM
SUZUKI SV 650S K4 seat & plastics suzook Stuff Wanted 3 04-02-06 09:49 PM
