Ok, looked on the Ohlins website and not got far … what are the numbers printed on the spring for a curvy ohlins shock (46HRCL) and what weight rider is that mapped around??
Basically I may have found a 2nd hand shock, but would like to know if it has been sprung about right before I agree to buy (the seller knows jack!!) ![]() |
#2 | |
![]() 46HRCL- showing the adjustments it has correct The part number for the SV is SU852(Ohlins site) which should be stamped on bottom Ally spring collar. I can't recall if it's which side of the collar base it's been ages since I had one of the piece of ****e :P ![]() The numbers on the springs(out of the box Ohlins) I believe is 1091-31 and again I believe is same spring rate as standard. HTH Cheers Ben |
#3 | |
The spring, if memory serves, is a .85, which is pretty soft. I'd assume that it's valved accordingly- you hear a lot from the SV Rider builder guys about how badly set up the Ohlins is as standard, but I can't really comment, since mine isn't standard. Just thought I'd mention that though.
#5 | |
Also i think you are wrong with the rate of the shock spring as standard anyways. My shock has an uprated spring on it and it's a 8.0 kilo one which i beleive is up from a 7.5kilo. Like i say though i could be wrong. also i cant even use SV650racer/sarah as a sounding board as she's off galavanting round jerez today ![]() You'll have to wait a see if rob somes along to tell all |
#6 | ||
http://www.racetech.com/evalving/eng...ngname=english remember that you get two springs at the front so you effectively get double the spring rate ![]() |
#7 | |
[quote="chunkytfg"]
#8 | |
Stock Shock Spring Rate 9.7 kg/mm (stock) Ideal Rider Weight for the Stock Spring 220 lbs or 100 kg I still don't know how to relate this to the Ohlins spring numbers ... |
#9 | |
Looked at my notes :P ![]() On the Ohlins springs you should have four sets of IDs' ![]() Also how much does Bluey weigh anyways ![]() ![]() Cheers Ben |
#10 | |
![]() I am about 12.5 stone, can go up or down by a few pounds depending on how strict I have been with diet and exercise ![]() |
Ohlins shock spring rates by rider weight | ads109 | SV Talk, Tuning & Tweaking | 16 | 15-09-12 11:14 PM |
Ohlins front spring, advise | gaal_alexandru | SV Talk, Tuning & Tweaking | 3 | 19-02-09 07:21 AM |
Ohlins shock for 02 curvy | FOO | Stuff Wanted | 0 | 05-10-08 08:25 PM |
Ohlins shock and other curvy race stuff | Robw#70 | For Sale - SV's and SV related items | 10 | 03-04-08 08:32 PM |
Ohlins shock. Shorter spring. | petevtwin650 | SV Talk, Tuning & Tweaking | 5 | 07-04-07 06:56 PM |
