Old 13-11-06, 04:02 PM   #1
Reckless Rat
Default PC Stuff: Using both connectors on an LCD monitor
Question is:
Can I damage an LCD type monitor by connecting 2 PCs to it
(one to the VGA, one to the DVI) and will it work OK if I do, using the screen menu
to switch between the two PCs???
RR
Old 13-11-06, 04:04 PM   #2
Filipe M.
Default Re: PC Stuff: Using both connectors on an LCD monitor
Originally Posted by Reckless Rat
Question is:
RR
Mine works perfecty that way (LG wotsit 19" LCD with both VGA / DVI inputs).
HTH.
Old 13-11-06, 04:06 PM   #3
Luckypants
Luckypants's Avatar
As long as you can select the input on the monitor should be OK? My Plasma TV handles several PC inputs by selecting the input channel manually, so the monitor would be OK to?
Old 13-11-06, 04:07 PM   #4
Baph
Should be fine, even for cases where you can't select the input, it usually prioratises DVI.
However, consult the manufacturer before doing it, just so you have no leg to stand on when you follow my advice & want to sue me for wrecking your screen.
Old 13-11-06, 04:10 PM   #5
Reckless Rat
Wow, that was quick!
Thanks all
RR
TRE Connectors df1uk SV Talk, Tuning & Tweaking 0 15-07-08 09:47 AM
Wiring connectors? CodeJACK Bikes - Talk & Issues 2 05-06-08 07:30 PM
cable connectors hovis Bikes - Talk & Issues 13 24-05-07 02:20 PM
electrical connectors riktherider SV Talk, Tuning & Tweaking 9 11-12-06 07:52 PM
Optimate DC connectors tigersaw SV Talk, Tuning & Tweaking 4 05-02-06 05:27 PM
