Old 13-11-06, 04:40 PM   #1
zog
Default Will a rear wheel from a 2002 fit a 2004?
Will a rear wheel from a 2002 fit a 2004? what else can i say?
part # are different , local Suzuki dealer doesn't know!
Old 13-11-06, 04:43 PM   #2
I think teh answer is yes, but it needs the spacers and bearings from a K3>
Old 13-11-06, 05:04 PM   #3
Mike1234
I think the bearings are already the right size but I wouldn't put money on it.
You will also need a different size rear disc.
Old 13-11-06, 05:15 PM   #4
Sprocket carrier bearing probably is, it's the same in loads of Suzuks. Pretty sure the wheel ones aren't though. I'd forgotten about the discs
Old 13-11-06, 05:30 PM   #5
Mike1234
It's the inner dimension of the bearing I was thinking of so the carrier one will be the same as the ones on the wheel.
A K3 wheel is 20mm, can't remember what the earlier ones were.
Old 13-11-06, 07:34 PM   #6
21QUEST
21QUEST's Avatar
Earlier ones are 20mm as well.
Ben
Nemo me impune lacessit.
Old 13-11-06, 07:34 PM   #7
In the carbed one, the carrier bearing has a bigger ID than the wheel bearings, and the spacer slots into the bearing- spacer id is 17mm, spacer od (and bearing id) is in the low 20s somewhere, could well be 20. Damn in all, I had this all written down, the bit of paper's been underfoot for months, and now I've lost it as soon as I want it.
Old 13-11-06, 08:32 PM   #8
NedSVS
curveys use a 17mm spindle, pointys a 20mm spindle. So you'll need to change the bearings and probably the spacer between the bearings in the wheel hub.
Old 13-11-06, 10:14 PM   #9
21QUEST
21QUEST's Avatar
Previuosly I wrote some bollix:
Ben
This is correct
Anyone that can tell me why I wrote that rubbish gets a prize
Ben
Old 13-11-06, 10:18 PM   #10
BILLY
Ben
This is correct
Anyone that can tell me why I wrote that rubbish gets a prize :lol
Ben
Whats the prize? some GSXR wavey discs
2002 rear brake lever ahzee Stuff Wanted 1 14-01-09 09:32 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Rear brake lever 2004 pointy Well Oiled Stuff Wanted 4 22-12-07 09:33 AM
Yamaha R1 2002/3 rear subframe (for the SV) riktherider Stuff Wanted 1 13-10-06 10:06 PM
2002 wheel fit 2000 model? kavana77 SV Talk, Tuning & Tweaking 3 09-09-05 10:21 AM
