Old 28-11-06, 08:30 PM   #1
hazey1275
Default Pilot jets ???
Does anyone know where i can get aftermarket pilot jets (possibly 175's) and also the 3mm washers for shimming the carbs?????
I've been reading some carb set ups off one of the links from the main page and would like to have a go at trying some different setups
cheers Hazey1275
Old 28-11-06, 10:16 PM   #2
svrash
Do you mean 17.5 piolt jets? the UK spec SV has these already Be careful when reading jetting from US sites as the carbs have differant parts, like the needles which are notched so you don't need shims persay, you only need one to give you a half step between the notches but you can use the washer above the needle for this
Old 28-11-06, 10:35 PM   #3
svrash
Here is a scan of the Suzuki workshop manual for the SV
E-02 is UK, E-33 is California and E-03 is the rest of the US
Forgive the copy of the scan, its been a well used book
Old 28-11-06, 11:24 PM   #4
hazey1275
Thanks for the help... i just wanted to try some different set ups with the main jets that i brought from your goodself..... Do you think its worth trying the drilled slide holes????
I was also wondering if anyone had tried running the sv with the universal k&n type cone filters?
All these things to consider whilst me bike is still in pieces
Old 29-11-06, 12:06 AM   #5
svrash
I've drilled the slide holes, finding the right bit can be a pain
Cone/pod filters are out of my league, i think it needs mega sized jets though
Old 29-11-06, 10:45 AM   #6
Huuuuuuge jets, in the 200s! Plus, with really good filters you need to modify the main air jets (these are pressed in so you can only drill them) and the float hrights as well. Hassle
Old 29-11-06, 11:28 AM   #7
hazey1275
I think i will stick with that desnorkled filter that i brought off you with the jets then, thanks for the advice
Nothwind have you managed to find the doc with the rear speedo drive conversion yet? I have tried to work it out but get as far as holding the drive in one hand and looking at the rear wheel....lol
cheers
Old 29-11-06, 11:51 AM   #8
Oh, balls. Sorry, I'd forgotten. Again. Do me a favour and send me a rude PM, or I'll forget again
Old 29-11-06, 03:48 PM   #9
hazey1275
I've sent you a pm prepare to be shocked........lol
Old 29-11-06, 05:07 PM   #10
riktherider
ive been thinking of getting universal cone filters on my sv aswell, but like others said, you need really large jets. is there any other crab that could be fitted?? going thoruhg streetfighter magazine it looks like a lot of the tuned machines in there use carbs of different bikes. any clues to which might fit and have the right jet sizes??
and also anyone know the diameter of the carbs?? although a rubber reducer could be used from the carb to the engine.
Pilot power vs pilot road James SV Tyres 30 18-05-09 10:20 PM
Michelin Pilot sport vs Michelin pilot road Dave The Rave Bikes - Talk & Issues 26 08-10-07 12:19 PM
Pilot Jets muska4star06 SV Talk, Tuning & Tweaking 4 01-06-07 11:01 AM
Pilot Power or Pilot Road? mario Tyres 3 06-10-06 03:45 AM
Michelin Pilot Sport or Pilot Power ? mihaip Tyres 0 22-09-06 12:02 PM
