Old 10-12-06, 06:32 PM   #1
Biker Biggles
Biker Biggles's Avatar
Default Clutch release worm gear.
Can anyone explain how this is meant to work?I seem to have broken it as the worm gear slides in and out of the housing but has nothing to purchase on so the worm doesn't turn.I assume there should be protrusions from the thin metal sleeve inside the housing but mine are not there.Is it worn out and do I need a whole new unit?
Old 10-12-06, 07:40 PM   #2
John Burt
Sounds like you've lost the little ball bearings from between the two sleeves - they sit in the helical grooves. Sorry can't remember how many or what size.
Old 10-12-06, 08:43 PM   #3
Biker Biggles
That would be it.The metal sleeve is a bit loose and there are no ball bearings so i reckon they have fallen out.I noticed the adjuster and locknut were showing too much movement fore and aft rather than in and out before I took it off.Anyone got a spare one?
clutch/gear peg Pam Stuff Wanted 1 07-05-08 09:09 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
Gear changing without the clutch metalmonkey Bikes - Talk & Issues 30 14-11-07 01:13 PM
Clutch worm drive thing for '00 curvy Ter Stuff Wanted 1 16-01-07 04:00 PM
Clutch release mechanism. Wilky_Boy SV Talk, Tuning & Tweaking 0 09-06-05 07:47 PM
