Old 23-12-06, 07:50 PM   #1
ejohnh
Default k2 naked - remove air filter housing
I started taking off the air filter housing today. But the housing to front carb clamp screw seems a tad inaccessible. Is it just a case of using a long screwdriver to get at it or is there a trick to it?
JohnH
Old 23-12-06, 11:13 PM   #2
netsurfer
I had this problem too... not sure if its the right way to proceed but I did the following:
Loosened the clamp for the rear carb seal
Pulled the airbox up, pulling the front seal away from the airbox.
Refitting is a little tricky getting the front seal seated again, however this was the only way I could manage to get the airbox off.
Pete
Old 23-12-06, 11:22 PM   #3
ejohnh
Pete
Thanks Pete. I'll see if any others on here give me any info before proceeding. I'm pretty p'd off with it really. The Haynes manual just says some crap about loosening the clamps and removing the housing, as if that was all there to it. All I want to do is to see why the choke cable doesn't work.
John
Old 23-12-06, 11:30 PM   #4
21QUEST
21QUEST's Avatar
Yes you need a long screw driver( I think it is a No2 Philips) for the front. Use a good quality one and make sure it is sitting properly before you attempt to screw or unsrcew.
To put it back on, attach the breather hoses as far in as you can then gentle wriggle the front on first. Then you can sit the rear. You may need to raise the front a touch to get the rear in.
Don't forget on the right(as you sit on bike) of the airbox there is the oil drain pipe. Make sure as you sit the air box it is actually going in next to the slot on the carb rail(?) and is not being caught by the electric wires on that side.
Before doing up the clamps make sure the the connection for the HT coil(Low tension side on left of bike) hasn't been accidentally unplugged when putting the air box on. A quick check is to start the bike and if it's has been pulled off, the tacho would register. Also check the breather hoses at engine end is sitting properly. Then you can do the clamps up. Not too tight mind.
Ben
Nemo me impune lacessit.
Old 23-12-06, 11:41 PM   #5
ejohnh
Ben
Thanks Ben,
I'm going to shove everything back together tomorrow and shoot up to Pontypool to see my sis. I'll get the sdriver on wednesday.
I dunno, since I got this bike in october, I have been adding to my tool collection at a hell of a rate. It's playing hell with my drinking too.
Merry Christmas,
John
Old 23-12-06, 11:54 PM   #6
21QUEST
21QUEST's Avatar
Originally Posted by ejohnh
...... All I want to do is to see why the choke cable doesn't work.
John
Aah the dreaded choke palava. If you lived closer to me I would have been happy to pop round to have a look. If only because I hate the SV choke playing hard ball . I've jus had to have a look at mine
It's probably the front (although I've had rear as well) that is the problem and that's the difficult one to get to without one breaking bits off the splitter if the whole carb is not being taken off. The rear you can check without much hassle.
At this point though I'll say again make sure you have good quality screw drivers. Ideally a long one(need that for the air box anyways) as well because the screw can be a b*tch to get off and you need to be apply sufficient leverage with a good quality tool without any slippage. Any rounding off due to the screw driver slipping would almost mean you won't be able to get them out without an impact driver(good to have that handy in any case).
With the air box off you could try checking the split for the choke cables to see if it is intact. If it has bits broken off it the cables may have been pulled out of the housing preventing them from operating as they should.
Be careful about getting dirt into the carbs or the engine if taking the carbs off. Some lint free rags slipped over the openings as I take either the air box or carbs off works for me. Then a clean around to make sure no dirt gets in when it's time to put carbs or air box back in.
EDIT: Another choke problem http://forums.sv650.org/viewtopic.php?t=49110
Merry Christmas to you John
Ben
ps: You replied as I was typing
Old 26-12-06, 04:50 PM   #7
ejohnh
John
Ben
HI,
I got the long one today. Checked the clamp screws. They loosened up like mmm er..... I don't know what ). But I was too 'merry' to go any further so I have left it til tomo probably. Where to get O rings and suchlike?
Happy New Year
John
Old 27-12-06, 12:14 PM   #8
I just leave the boot attached to the carb, and pull the airbox off its boot. I'm sure it's not supposed to do that, but it's miles easier.
Old 27-12-06, 03:11 PM   #9
ejohnh
Default Fine until now!
It was going too well.
Air filter housing came off easy. Then I used two small freezer bags and elastic bands to seal the air intakes - fine so far.
Sh*t!!! someone has tried to take out the rear carb choke plunger screw with a rusty nail! No sign of a phillips/crosspoint shape left!. Last time I used a stud extractor the damn thing broke off in the stud!
Any ideas guys? Mine is to displace the rear carb and try to get a small mole wrench onto the screwhead. Any others?
John.
Old 27-12-06, 03:23 PM   #10
fizzwheel
fizzwheel's Avatar
Molegrips might do it, Is there much of a head on the screw left ? If so get yourself a junior hacksaw and cut a slot in whats left of the screwhead and then get a nice big flat blade screwdriver and see if it'll turn with that. I suspect though that screw is properly rusted into the body of the carb. like mine was. I ended up wedging a flat blade screwdriver onto the head of the screw and then banging the screwdriver with a hammer. A few deft blows with the hammer broke the rust seal on the screw thread and then I was able to undo it.
Its easier to do this with the carbs off the bike though.
Note : according to Sid Squid who knows about this stuff, beating your carbs with a big screwdriver and hammer isnt really a good idea as it might do more harm than good. Just be careful.
HTH
Thermostat Housing cammy SV Talk, Tuning & Tweaking 4 24-04-09 09:29 PM
Curvy N Rev counter housing punyXpress Stuff Wanted 6 19-03-09 05:45 PM
Sidelight housing Saint Matt Stuff Wanted 0 23-08-06 05:01 PM
K3-5 Fan housing jamesobrady Stuff Wanted 4 29-07-06 04:28 PM
How secure should the air box / air filter housing be ? csimmo Bikes - Talk & Issues 5 24-04-05 05:56 PM
