Old 27-12-06, 08:26 PM   #1
husky03
Default cam chain tensioner question
Hello-when changing the cam chain tensioners is it just a case of undoing the two bolts and removing them or do you need to do anything else before there removed?.
husky
Old 27-12-06, 08:45 PM   #2
netsurfer
Not entirely sure, not got that far myself, however check out the service manual for the information you require http://www.sv650.org/SV_service_manuals/3_Engine.pdf
cfn
Pete
Old 27-12-06, 08:56 PM   #3
instigator
Hi mate
Yes it is. Although best if you can make a tool so that you wind in the tensioner (remove the middle 10mm nut) so it is easier to remove.
Gaskets might be gubbed, they're about £1 each. I rounded off my cct bolts too. Best to buy replacements if I am honest.
Good luck with swapping them. I guarantee you'll break something through frustration if you haven't played about with them before.
Old 27-12-06, 09:00 PM   #4
husky03
cheers guys-going to get them done tomorrow.
husky
Old 28-12-06, 12:57 PM   #5
Some people say to always do it at TDC... I never have, since I don't check timing afterwards it'd probably make no difference but then, maybe the chain's less likely to skip at TDC. I don't really see any risk of it jumping time as long as you don't turn the engine with the tensioner out, confident enough of that to do it myself but I wouldn't want anyone else to depend on it
Not a bad idea to remove the engine plug and turn the crank by hand (well, by big wrench) before starting though, that'll tell you quick enough if the chain's jumped enough to mangle the valves. Very unlikely that that would happen, IMO, but when it takes 5 minutes to check there's a good case for needless redundancy
Help need a cam chain tensioner freebird SV Talk, Tuning & Tweaking 25 29-09-08 12:18 PM
cam chain tensioner gc350 For Sale - SV's and SV related items 4 30-08-07 08:47 PM
Cam Chain Tensioner Banus SV Talk, Tuning & Tweaking 1 22-07-06 05:05 PM
Cam chain tensioner Blue_SV650S SV Talk, Tuning & Tweaking 2 07-07-06 08:38 PM
Cam chain tensioner. Stig Stuff Wanted 8 11-12-05 06:14 PM
