Old 29-12-06, 05:54 PM   #1
Viney
Default Home network help
I need help sharing folders on my PC with my laptop.
Details below
Laptop running XP pro and Norton (latop using a Wireless usb dongle)
PC running Xp and norton (PC Lan into router)
Netgear router/modem
What do i need to do. I have tried all the wizards but it dont seem to work.
Step by step please
Old 29-12-06, 06:56 PM   #2
jonboy
Norton? You're a brave man .
Why not just plug the laptop into the desktop, using the LAN ports on each machine? That should work instantly (he says ). Though you may need to create a new network connection.
Old 29-12-06, 07:05 PM   #3
rictus01
rictus01's Avatar
First off Ian, are you using any security on your wireless network ?
as without it anyone within range can hijack you shares or Internet connection
you should have wep encryption 128 bit, and I'd advise registered MAC's as well.
to share a folder in XP just select the required folder and right click on it, select "sharing", with in the top dialog box click "share anyway" (or something like that) if you don't need to setup permissions. the folder shoild show a cupped hand under it.
from another machine going through network niegbourhood select the machine, this should show all shares on that machine. select the one you want and you should have access (both read & write).
Cheer Mark.
Old 29-12-06, 07:42 PM   #4
Viney
Cheer Mark.
Mark, yes running 128 bit Wep and 'This machne only' in the access list.
Done waht you said but the shared folder does not show up in the network Nieghbourhood thingy. I get 3 options
MS Terminal services
MS Windows network
Web client network
I go into all 3 and nothing shows.
JB. Been using norton for 5 years now and never had any issues, then again i dont do anything major.
Old 29-12-06, 07:52 PM   #5
rictus01
rictus01's Avatar
have you created a workgroup or domain ?
in the MS window network you'll find it if you have.
if not go to the "My computer" icon, right click and select properties.
you should see something like network ID, set up a workgroup and call it something like "home", do the same on the other PC.
you should now find this network in your network connections.
(can't give exact as I'm on a 98 machine).
Cheers Mark.
Old 29-12-06, 07:54 PM   #6
fizzwheel
fizzwheel's Avatar
OK can you do a basic check for me. On your PC
Click on "Start" then run, in the little box that comes up type in "cmd" and then hit return, this should pull up a DOS window. in the new window type in ipconfig and then hit return. You'll get all sorts of stuff up that looks like gibberish...
in the first couple of lines it'll say "IP Address ....... : " then some numbers. Make a note of the numbers it'll probably be something like or at least in this format 192.168.0.2
On the laptop Click on "start" then run, in the little box type in "cmd" and then hit return, in the DOS window that comes up, type in ping followed by the numbers that came up on the PC i.e.
"ping 192.168.0.2" and then hit return. if you get something up like this
reply from 192.168.0.2 with some more numbers that tells me that the PC and the laptop are talking to each other. If they are not you've got a networking problem.
This is what it looks like on my laptop
Now I know that Liz's laptop on the same wireless lan is 192.168.0.3 so this is what I get back when I ping her laptop, you should get a simialr result if you try and Ping the PC from your laptop if everything is working as it should be.
I've got a netgear wireless router so I can't see any reason why it shouldnt work.
If they are then do what Rictus has just posted and make sure that the Laptop and the PC are in the same workgroup, then follow the rest of his instructions.
OK these are the screens that Rictus is talking about, this is what should come up if you right click my computer and choose properties
click the "change" button and then make sure that on both PC's you have the same text in the "workgroup" box, doesnt matter what it is as long as its the same
Make sure that your PC and the laptop don't have same name though otherwise it wont work.
Old 30-12-06, 10:06 AM   #7
TEC
TEC's Avatar
All good advise but if that Norton is a firewall then nothing will work unless its permitted through Not sure where the setting is (I hate NOrton as much as the next person) but you will need to add in allow traffic from the IP address of the PC/Laptop (needs to be done on both), much hair pulling if not done
I am behind you
http://wildwesternadventures.com/
TEC is offline   Reply With Quote
Old 30-12-06, 11:13 AM   #8
Viney
Cool guys thank you. I will try that out later today.
I think that there might be some norton stuff going on. I think i know what the settings are as well
Old 30-12-06, 11:45 AM   #9
timwilky
timwilky's Avatar
Yeah anti virus software can be a right pain in the ****. The first thing I did when I upgraded my laptop to xp was to rip out and disable warnings about the Microsoft firewall. All my stuff sits behind proper firewalls so I don't need to slow down PCs with extra garbage. But I really struggled with my mail. I was convinced there was something wrong with my mail server as it would not accept smtp connections. I knew it could not be my new laptop as also a telnet to port 25 would not connect either, Yet if I moved the port on the server everything was ok.
Only when I tried another pc that worked did I start looking at the new laptop and when I turned off the anti virus it suddenly connected. Doh. the antivirus also stopped outgoing mail. BTW that was McAfee VirusScan Enterprise
Not Grumpy, opinionated.
Old 30-12-06, 11:53 AM   #10
Viney
Woohoo, i doine it. I went through the firewall on laptop and pc and made sure that they permit each other only to connect and roberts my das brother.
Thank you to the above
I also just noticed that this is in the soho bit. Sorry about that
o2 sim/tesco network irnbrumad Idle Banter 5 13-04-09 10:50 PM
3 network jamesterror Idle Banter 10 09-04-09 12:57 PM
Wirless Network help... Please? 454697819 Idle Banter 3 14-07-07 11:14 AM
Mobile network '3' THREE quikstu Idle Banter 6 09-03-07 11:41 AM
Small Office/Home Network Types (Suggestions Needed) Demonz Idle Banter 21 13-10-06 08:30 PM
