Old 13-01-07, 10:08 AM   #1
bikerskez
Default FITMENT OF LOWER FAIRING
Morning all,
I was wondering if anybody else has has a look at the SV sport? imparticular at the little brackets that attach the fairing to the radiator. I never got any brackets that look like that in my fitting kit and have only ever been able to attach one side of the fairing to the radiator. Has anybody else had this problem?
Old 13-01-07, 10:53 AM   #2
hovis
just been out to check
if you have OEM suzuki lowers there is a bar that bolts to the bottom of the rad with threades at each end
if you have after market ones i think there is a bar on each side that bolts to the rad & then somwhere lower down?
Old 13-01-07, 02:49 PM   #3
hovis
BUT................it now looks as if you have a pointy only just noticed your picy.....sorry
Old 13-01-07, 03:10 PM   #4
Dan
Default Re: FITMENT OF LOWER FAIRING
Originally Posted by bikerskez
Morning all,
I have a set of lowers i bought off eBay and the fitting kit didn't include these brackets either. If you find anywhere you can get them, please let me know. If not I'll have to fabricate something myself.
Old 13-01-07, 05:58 PM   #5
on my thou theres no brackets there? the fairing fixes directly to the rad.
Old 14-01-07, 01:12 PM   #6
Dan
The problem seems to be that on the K5 650 the rad was made much narrower, I presume to prevent it being damaged in a drop - I'm amazed how wide the rads on the earlier pointies are.
I guess the thou probably has a wider rad as well due to the larger capacity motor. This bracketry problem seems limited to the 650 from K5 on.
k6 lower fairing gralln9 Stuff Wanted 0 04-08-08 03:20 AM
Lower Fairing K4 Shellywoozle Stuff Wanted 2 16-09-06 10:21 PM
sv lower fairing, red djc103 Stuff Wanted 0 06-06-06 03:50 PM
Looking for lower fairing kidpuffy SV Talk, Tuning & Tweaking 1 23-04-06 06:25 AM
Lower fairing inlet scoop screw & top fairing clip Mr. Marcus Stuff Wanted 2 05-12-05 09:18 PM
