Is the SV650 already restricted from standard because everywhere i read it says the SV's top speed is 200kph 125mph but on here i read somewhere that they go up to nearly 140.
Is this because of aftermarket accessories? |
Naked 650 will do around 125, faired will do around 135 - aftermarket accessories such as can, filters etc won't make a huge difference on top speed
2000 - 2004 SV650S 2004 - 2009 SV1000S 2009 - 2013 Triumph Sprint ST1050 2013 - 2016 Triumph Explorer 1200 2016 - Ducati Multistrada DVT S ![]() |
#3 | |
The only way to get a stock SV to a genuine 140mph would be to ride it down a cliff... The power drops off hard as you approach the limiter. Very few people will claim to have hit the limiter in top on a standard bike, and then you get the exagerration effect.- I think mine probably would, as it's nicely up on power, but the rate of climb drops right off after you hit a real 125. You'd need real patience and a lack of mechanical empathy to get it all the way. Or much lower gearing
i've had an indicated 140 - so about 120/125 real - and that was on the limiter in 6th, so i don't think you could go any faster on standard S gearing.
i'm not sure if i technically hit the limiter though - it was reading around 11.5krpm in 6th (so 500rpm into the red) and that was approximately where the limiter had been hit in other gears ![]() i must have a lack of mechanical empathy ![]() |
my fully faired curvy used to top out at an indicated 139mph. when i changed my front tyre i went up 10 on the profile and now it does 129mph. i feel that this has made the speedo very accurate.
#7 | |
I worked it out a while back, and running the speedo on a 120/70 reduces the error by about half. Running it off the rear with the 160 makes it closer again.
#9 |
Thanks alot people
Can they tell it's not restricted? | GeneticBubble | Bikes - Talk & Issues | 214 | 25-03-09 12:45 PM |
K8 restricted ecu | Whitehouse | SV Talk, Tuning & Tweaking | 2 | 21-01-09 12:20 PM |
ECU - SK3 (Non Restricted) | bobit69 | Stuff Wanted | 0 | 29-05-07 09:54 AM |
Restricted her, restricted there. | graeme1841 | SV Talk, Tuning & Tweaking | 6 | 10-07-05 01:09 PM |
Is it restricted? | Mimu | Idle Banter | 0 | 07-01-70 05:16 AM |
