Old 17-01-07, 11:40 AM   #1
Kylie
Kylie's Avatar
Default Rapidly going off rain...
Last winter rain was no problem to me, but this year its a nightmare. My trusty Shoei pin lock system mists up quickly, my toasty Racer waterproof gloves get damp, my Bering waterproof trousers are leaving me with a nice wet crotch and the tried and tested wipe visor with finger technique doesn't seem to clear much water anymore. Either this years rain is nastier than last years, or I'm getting sweatier (and incontinent!) as I get older, or my kit is deteriorating. I reckon its the latter.
So I reckon I need to buy:
Some kind of waterproofing (spray on / wash in?) to fix the gloves and trousers
Some anti-fog spray for the visor
A vee-wipe or similar, or maybe even some magic water-repellent gunk for outer visor?
Recommendations appreciated!
I'm Mike. Kylie is an SK3 with OE lowers, R&G bungs, OE double bubble, Scottoiler, Starcomm, Hamicad tail tidy, bruised and in need of a wash.
Kylie is offline   Reply With Quote
Old 17-01-07, 11:55 AM   #2
rigor
Default Re: Rapidly going off rain...
Most waterproof kit, at some stage in it's life will need re-waterproofing. Hein Gericke do sell a waterproofing spray that you spray onto your kit and leave to dry (from memory, I try not to ride in the rain ). As for the visor, I'm surprised that it's starting to fog up, it's probably worth having a good look at the seals, to make sure they are still good, and maybe taking it off, drying it out and re-fitting. Failing that, I like to use the pink spray on stuff from HG (again, I should be on commission) It works for me. As for the outside of the visor you can get another spray on chemical (HG again) that makes the water bead up a lot more, which means that the drips flow off the visor with just a turn of your head, or a quick wipe.
HTH
Old 17-01-07, 11:57 AM   #3
thor
rainex for the visor - bloody brilliant
Great for the car too. Motorway miles with no wipers needed.
Old 17-01-07, 09:24 PM   #4
adamfool
have you checked that the insert hasnt 'slipped'? its quite common for the inserts to slide down the inside of the visor, creating a small gap between the two.
Old 17-01-07, 10:02 PM   #5
Beenz
I tried Rainex on my XR1000 visor and didn't get on with it, the big blobs of rain flew off a treat but it left tiny drops that I could not get rid of even by wiping. In the dark this made clear vision difficult with the lights of traffic in the opposite direction. I'm not saying it does not work, just that It did not work well for me thats all.
If misting is a problem (I find the pinlock works very well) try Bob heath anti fog or use some slightly washing up liquid on the inside.
Old 17-01-07, 10:22 PM   #6
fizzwheel
fizzwheel's Avatar
I'd suggest that this is probably not the good idea it seems. Remember washing up liquid has salt in it. Which will scratch your visor if you rub to hard whilst wiping the washing up liquid on your visor. Trust me I've done it.
Also Rainex according to the fine print on the bottle isnt recommended for visors. Halfrauds do sell a very similar product that is though.
As for misting if your pinlock isnt working its probably not "stuck" to the visor properly. Try removing and cleaning it and the slightly moistening the silicone bead around the edge of it before re-attaching. Also consider a "Foggy" Respro mask. Can be a bit claustrophic but it will stop you breathing on your visor and fogging the inside of it.
Old 17-01-07, 10:37 PM   #7
Heed
ON the back of this thread I've jusyt bought a foggy respro mask. I use the caberg V2 helmet. Fogging isn;t too bad on the main visor but on the drop down tinted one it's terrible. I'm hoping that this will sort it out.
Old 17-01-07, 10:43 PM   #8
Biker Biggles
Biker Biggles's Avatar
Ive used washing up liquid on my visors and not had a problem with scratching.i don't rub it in,just smear a bit on with water.Maybe it's cos I use that Fairey stuff----Soft on your skin/soft on your visor.
Old 17-01-07, 11:34 PM   #9
Baph
Originally Posted by Biker Biggles
Ive used washing up liquid on my visors and not had a problem with scratching.i don't rub it in,just smear a bit on with water.Maybe it's cos I use that Fairy stuff----Soft on your skin/soft on your visor.
I'm the same. My trick is to put a TINY amount of Fairy in a dish, fill up most of the way with almost-boiling water.
According to the advert, a little fairy goes a long way.
Then I use a TINY amount of the solution (after allowing the water to cool) on kitchen roll. Wipe the visor gently inside & out. Then repeat with JUST water. Then repeat again with dry kitchen roll.
Works a treat, and haven't seen any scratches. I figure there's a small amount of salt in the washing liquid, and I use a tiny amount of that, diluted, settle a little, a tiny amount of that & then I'm gentle. So the risk is minimised.
Old 17-01-07, 11:41 PM   #10
ejohnh
I take it that is the homeopathic approach to visor preparation?
Will the rain ever end??? Kate Moss Idle Banter 22 07-07-07 11:34 AM
Rain Rain, Go Away... the backup plan! Ping 2007 Annual Rideout 39 29-06-07 09:31 AM
SVs in the rain. Taipan SV Talk, Tuning & Tweaking 15 13-05-07 03:53 AM
i'm fed up with rain now :( kwak zzr Idle Banter 13 12-05-07 11:52 AM
sv and the rain BIKER-DENE SV Talk, Tuning & Tweaking 6 17-02-06 07:32 AM
