Old 17-01-07, 03:48 PM   #1
yans_sv
Default 2007 Oxford Hot Grips
Chaps,
I made a purchase of the lastest Oxford Hot Grips cos the ones i had (previous Oxford Hot Grips with the turny nob) died - well, the control button to adjust the temperature stopped switching on and off! The new ones are more sexy with LED's and stuff...... but...
...i installed the new control module as it was just a case of unplugging old one and plugging in new one but the damn things switches off when you are idling, ie, at the traffic lights! and they dont switch back on when you start moving....
anyone know if there is a way to by-pass this, otherwise these badboys are useless to me as my journey is stop start stop start to work
Thanks all!
yans.
Old 17-01-07, 03:57 PM   #2
Baph
Where is your controller wired into?
IIRC, they're designed to cut the power after the ignition dies, so they should have no knowledge of engine speed!
Old 17-01-07, 04:02 PM   #3
thor
Wow, oxford don't seem to have a good track record do they!
Old 17-01-07, 04:03 PM   #4
yans_sv
they are wired into the spare fuse in the fuse box...... exactly as the previous ones were and they worked a treat...
... i think these one are far more intelligent and do sense current or something and check whether revs are being applied by the amount of current running through them.... getting a bit out of my depth here!
these things are too intelligent which to be honest, i dont need!!!
Old 17-01-07, 04:21 PM   #5
Baph
If it's wired to the fuse box, it takes positive from the same place as mine. Namely, the ignition.
Where is it grounded to?
The ignition circuit doesn't give a hoot about engine speed, so I can't see the positive wire affecting things. Maybe they're getting too hot & cutting out?
They are more advanced than the older ones, but not by much, and I wouldn't trust that low battery cut off they have, even if it worked properly!
Old 17-01-07, 04:49 PM   #6
hovis
Default Re: 2007 Oxford Hot Grips
Originally Posted by yans_sv
Chaps,
Thanks all!
yans.
this is because when your battery gets a bit low they turn off.......try charging your battery 1st
Old 17-01-07, 04:57 PM   #7
Hum. I'm thinking it could be to do with the charging system. The grips can't sense revs, but if there's something monitoring battery status then that's got the capacity to tell when the charge drops- and the bike will produce less power at idle than at revs. It shouldn't really make a difference, but maybe if your charging system's not 100% the voltage would drop far enough to set the box off.
Old 17-01-07, 05:07 PM   #8
Baph
Possibly an early warning of Reg/Rect failure etc then.
Stands to reason to me. I was actually thinking along similar lines, but only if the grips are grounded to the battery, as opposed the frame. Charge variations could come into account that way if combined with a dodgy earth in a number of places.
Old 17-01-07, 05:19 PM   #9
hovis
[quote="Baph"]
quote]
i would think so?
Old 18-01-07, 08:03 AM   #10
yans_sv
thank you all for your thoughts.
i have contacted the shop i bought them from and they are going to speak with their Product Manager at Oxford and get back to me. As I said, the previous model of these grips (on/off turny knob) worked perfectly - this model definately has some form of sensing (not sure what) inside the control unit that is quite frankly OTT!
a colleague at work says his original honda heated grips switch off at idle but kick back in when revs are up again (or a higher voltage is detecting due to charging)!
ah, the whoes of being a panzy on these cold mornings!
thanks again all - keep the thoughts coming in! i will keep you posted as to the Product Managers views.
Oxford Hot Grips Girth For Sale - SV's and SV related items 3 12-04-09 06:15 PM
Oxford Hot Grips Wadda For Sale - SV's and SV related items 1 15-02-08 01:55 PM
Oxford 2007 Hot Grips (new) markmoto For Sale - SV's and SV related items 2 19-09-07 03:34 PM
Oxford Hot Grips Richie Ancillaries 13 02-01-07 11:48 PM
Oxford hot grips not hot !!! chutz SV Talk, Tuning & Tweaking 3 16-01-05 10:50 PM
