Old 22-01-07, 10:20 PM   #1
antony
Default sv race emulators
can anyone explain a simple way fo instructing me how to fit i removed rods and drilled holes then inserted emulators now do i have to cut some off the top spacer to compensate for the emulator being in any info would be great cheers
Old 22-01-07, 10:29 PM   #2
chazzyb
Can't the supplier advise? I've been contemplating getting a pair for my curvy. Where did you get yours?
Old 22-01-07, 10:33 PM   #3
antony
got mine from pdq will have to ring em again for more advice they were 112 pounds if i remember right
Old 22-01-07, 10:47 PM   #4
svrash
Save your money, do a gixxer front end conversion and sell your old bit
Old 22-01-07, 11:15 PM   #5
lukemillar
Yep - that's the idea. If you still have the forks off the bike then it's easy to do a dry run with and without the emulators in to work out the difference. Have you changed the springs as well or are you still using the stock ones?
Old 22-01-07, 11:28 PM   #6
antony
using ktech 8.5 springs set up for my weight have put two turns of compression on emulators only using bike on track thought that i would have to take off about twelve mm off the spacers
Old 23-01-07, 01:17 AM   #7
Hmm, I wasn't under the impression that the emulators required changing the spacers...
Old 23-01-07, 08:42 AM   #8
lukemillar
Depends on the bike. I bought mine direct from Ractech and they sent me a length of ally pipe as spacer material in case I needed it. My old spacers had already been cut down to use different springs, they weren't much use and I had to make new ones. Maybe I'm not the best person to comment (i.e not going from stock), but I 'm sure if he's changing the springs as well, then would probably need to alter the spacers.
Old 23-01-07, 10:05 AM   #9
Depends on the springs
Old 23-01-07, 11:11 AM   #10
lukemillar
I will bet you one of your Scottish pounds that he has to alter his spacers!
Race tech gold fork emulators FOO SV Talk, Tuning & Tweaking 2 31-10-08 06:44 PM
SV-650K7 & Race Tech Cartridge Emulators YZEtc SV Talk, Tuning & Tweaking 18 09-12-07 10:50 PM
Emulators RingDing SV Talk, Tuning & Tweaking 27 07-07-06 07:49 PM
Emulators? Jester666 SV Talk, Tuning & Tweaking 6 06-07-06 08:17 AM
Emulators - Race Tech or Traxxion RingDing SV Talk, Tuning & Tweaking 10 02-06-06 08:57 PM
