Old 29-01-07, 03:18 PM   #1
budrosmith
Default ignition button does nothing
Hello again, I have a 99' SV naked model and was involved in a small spill just last night. Right after I picked the bike back up and tried to restart the engine the ignition button did absolutely nothing. It was like I wasn't pushing nothing at all. The starter didn't turn, nothing (you got the idea). Luckily there was a downhill slope as I pulled into a shopping center and I was able to push start it with ease right after-wards. What on earth could it be.
Thanks for looking,
Budro
Old 29-01-07, 03:24 PM   #2
hovis
clutch or stand switch?
Old 29-01-07, 03:27 PM   #3
svDaveC
Sounds obvious but.... killswitch?
Old 29-01-07, 03:29 PM   #4
budrosmith
yeah that's crazy I just got done slicing the wires and connecting them directly to bypass those switches
Old 29-01-07, 03:31 PM   #5
budrosmith
yeah the killswitch is off as well, I was hoping that it would be something simple myself
Old 29-01-07, 03:38 PM   #6
petevtwin650
Well the bike runs, so it isn't the sidestand or kill switches. I'd have plumped for the clutch lever one but you say it's not that. Obviously the starter motor is isolated. Which side did the bike fall on?
Old 29-01-07, 03:44 PM   #7
budrosmith
yes, your right I myself am really leaning to the clutch switch as well but those wires are looped unless there is a break in the wires passed that (hmm let me go check on something real quick)
The accident was on the clutch/ left side.
Old 29-01-07, 04:05 PM   #8
budrosmith
Default well alright
well thanks for your help, if you got anymore suggestions I will gladly take em'
Old 29-01-07, 04:18 PM   #9
Baph
Just looked at the wiring diagram:
From the side stand, the current flows to the kill switch, to the starter button, to the clutch switch, then on to the starter motor.
The side stand is fed from the fuse labelled "4" on the wiring diagram. This actually takes current from the ignition switch (key).
The fault HAS to be somewhere along that line.
HTH.
Old 29-01-07, 04:55 PM   #10
petevtwin650
Don't want to appear a numpty, but you have checked the main fuse haven't you?
Faulty start button Mark_h SV Talk, Tuning & Tweaking 10 23-03-09 12:17 PM
show us your belly button hovis Photos 13 17-10-08 10:18 PM
do not press the red button johnnyuk Idle Banter 6 26-09-08 03:48 AM
SV650 Starter Button? Torn-Thorax SV Talk, Tuning & Tweaking 3 09-09-06 02:49 PM
