Old 31-01-07, 08:08 PM   #1
Normski
Default Sidestand switch cable routing.
I'm going to have to replace my sidestand switch but I'm worried because the cable leading down to the switch runs behind a casing and is stiff to pull through. I can't see any way of pulling the connector through. Can I take this case off, or am I missing something?
Old 31-01-07, 08:21 PM   #2
Lissa
Just Ballast
Lissa's Avatar
According to Haynes, the connector is under the tank. To find it you'll need to trace the wires back from the switch. The reason why it's reluctant to pull through is because it is held in place along the frame with ties and clips.
Old 31-01-07, 08:26 PM   #3
Normski
I've found the connector just worried how I'm going to get the old one out and new in through a tight space - will have a look for cable ties in better light at the weekend.
Old 01-02-07, 08:07 AM   #4
I seem to remember that it passes under the front sprocket cover, if I remember right then it's a simple matter of 3x8mm bolts to remove it, and yes it will be clipped in place so it's most unlikely that it will just pull through.
Old 01-02-07, 06:07 PM   #5
M1TCH
^ yep, less than a minute to get the cover off. its dirty behind there too.
Cable routing info needed. Jay12329 SV Talk, Tuning & Tweaking 4 13-05-18 11:44 AM
Routing through some photos and found these mister c Photos 22 25-05-08 02:32 PM
Wiring Harness,cable and hose routing 21QUEST SV Talk, Tuning & Tweaking 3 19-05-07 04:48 PM
Pic of rear hose routing? andy SV Talk, Tuning & Tweaking 7 07-05-07 08:49 PM
Help!!pic of sidestand switch needed dmc2373 SV Talk, Tuning & Tweaking 1 07-02-05 10:25 AM
