Old 05-02-07, 12:24 AM   #1
Spudsta71
Default Fitting a uk spec front light unit onto an import machine
Forgive me if this subject has been covered previously - I did take Sid's advice and look on the search link but couldn't suss anything out.
Does anyone know if the wiring for the front light unit on an import machine (Y reg 650) is the same as the uk spec bike?
Essentially what I need to know is, if I buy a uk spec front light unit, will it be easily interchangable with my existing light unit?
Thanks.
Old 05-02-07, 01:28 AM   #2
rictus01
rictus01's Avatar
No the wiring isn't the same, however you can get a UK front loom that plugs straight in or as I did just cut the plugs off the one you have and wire on 2 H4 bulb connectors.
Cheers Mark.
Old 06-02-07, 07:35 PM   #3
Tim in Belgium
Just fitted the new bit of the loom myself as I've brought the bike over, the part costs about 10-15 quid from breakers (headlight wiring loom). It is then just clip in and play (and faff about with the fairings!).
SV 650S Engine fitting 00 machine. aln Stuff Wanted 3 29-11-08 11:54 AM
GSXR K7 K8 seat unit fitting? weecorey Mini-Twins 8 02-10-08 10:14 PM
Front headlight unit Jase22 For Sale - SV's and SV related items 2 24-04-07 07:53 AM
UK Spec Curvy 650 S Headlight Unit Spudsta71 Stuff Wanted 4 23-03-07 09:46 AM
UK SPEC FRONT LIGHT UNIT FOR 2001 CURVY SV650S Spudsta71 Stuff Wanted 1 10-02-07 07:59 AM
