Old 08-02-07, 07:22 PM   #1
pete m
Default Card readers - how do they work?
Ive had a nokia phone with all singin 'n dancin pix, video, music, radio etc etc for a year....finally bought meslef a card reader - im pretty sure its the right type - SD...but i cant make it work...
The maxell helpdesk said i had to do some complicated stuff to do with resetting the USB driver settings (or something)....no good, couldnt get near it, the things they siad would happen didnt & werent there in the first place...which made me think the Windows 2000 OS ive got might be the problem, but it should work with that...
so - anyone got any clues , the manual talks about connecting the phone, and doesnt mention doing it by the memory card, but theres no way of connecting the phone to the pc without bluetooth (not got)
SO does anyone know what to do, got any experience of this problem...
Old 08-02-07, 07:28 PM   #2
TSM
The Sick Man
TSM's Avatar
Its possable that the reader is trying to mount itself on drive letters that are already in use, this can happen with many readers and needs a little bit of a rummage though the Computer Management panel.
Old 08-02-07, 07:32 PM   #3
pete m
TSM - yes - thats what the helpdesk bod said but his directions to fix just dint begin to work - thats why i mentioned my ancient OS, i probably wouldnt have these problems if i had XP or Vista, thing is if you mess with that, do you lose all your 2000 data ?
Old 08-02-07, 08:11 PM   #4
Blue_SV650S
Default Re: Card readers - how do they work?
I'd throw the card reader back at them and just buy a bluetooth dongle ... they are not expansive ... for example:- Dongle
Old 08-02-07, 08:18 PM   #5
pete m
that does look like the perfect solution, its just that i dont think the phone has bluetooth capbility - nokia 6230i - you see them everywhere !
Old 08-02-07, 08:29 PM   #6
Blue_SV650S
{quick check}
I think it does (has a tick besides) 6230i Spec
The other thing to do is to buy a data cable and use the nokia data suite thingy ... again ... ~£5 for a data cable clicky .... I'd go data cable over bluetooth myself ... the transfer rate on bluetooth is pretty pap and setting it up can be a sod!
Old 08-02-07, 08:53 PM   #7
pete m
thanks again - i knew thered be something like that out there - might just o for that, makes the memory card redundant doesnt it ?
btw blue sv - i might have a proposal for you to do with trackdays ( have a look at 2onT - click sig), are you in London much so we could meet?
Old 08-02-07, 09:10 PM   #8
Blue_SV650S
You will still want the card in the phone, but you won't need a card reader (or is that what you meant?!? )
Unfortunately (or should that be fortunately? ? ) I pretty much never have cause to go to London, but it looks like you cover many of the race meets/trackdays, so there is a chance we might both be at the same event at some point!? ... What did you have in mind anyway?
Old 08-02-07, 09:16 PM   #9
pete m
ill pm you later
& you Mr Toad - cheers !
Benefits (or thieving scum, for Express readers) MiniMatt Idle Banter 2 16-06-08 02:57 PM
Card Trick, Anyone? Lissa Idle Banter 29 20-12-07 11:29 PM
USB2 PCI card. Richie Idle Banter 10 31-08-06 08:43 PM
Sd card 128 MB and card reader Quiff Wichard Idle Banter 15 15-06-06 09:17 AM
Mrs McCartney - sick joke, may offend some readers. inevitable Idle Banter 49 01-06-06 11:29 AM
