Old 19-02-07, 08:08 AM   #1
Amanda M
Default SV1000 clutch
Hi folks
Am I right in thinking that the SV1000 has a hydraulic clutch? If it has can someone have a look to see what size bore it has. I'll be especially happy if it has a 5/8" bore because one will fit on my FZX750 and let me put an adjustable lever on it
Amanda
Old 19-02-07, 10:26 AM   #2
jambo
jambo's Avatar
Default Re: SV1000 clutch
It does have a Hydraulic clutch. Not sure on the bore but I'd have thought it'd be the same as different brake M/C configurations, i.e. different feel but should still work. I'm more that happy to be corrected on this one though. Don't suppose there's an adjustable Brake lever that'll go on the FZX M/C?
Old 19-02-07, 10:59 AM   #3
Amanda M
I'm afraid there's no adjustable levers for the FZX - it's an old bike you see, which is why I'm asking about SVs and the like. All I know is no other (modern) Yams have that size M/C and so I can't fit one with an adjustable lever to it. We tried one with a smaller bore to see if it would be lighter but the clutch wouldn't engage. Doh!
Cheers Jambo
Amanda
Old 19-02-07, 11:03 AM   #4
jambo
jambo's Avatar
Cheers Jambo
Amanda
Ah right, Do you know the stroke as well as the bore? As presumably you're after the same displacement of fluid. so a Bigger bore & shorter stroke would be ok (If possibly a bit stiffer)
Old 19-02-07, 11:14 AM   #5
Amanda M
I've no idea about the stroke of it, but ideally I don't want it to be stiffer because at the moment it's heavy but OK. I need the adjustable lever from something more modern because I'm ending up with tendonitis because of the stretch to the lever (I've got really small hands!).
Amanda
SV1000 Clutch - Shoud I be worried Girth SV Talk, Tuning & Tweaking 9 26-05-08 10:15 AM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
SV1000 Clutch question. Mark_h SV Talk, Tuning & Tweaking 5 03-11-07 02:52 PM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
