Old 27-02-07, 11:06 AM   #1
tapemonkey
Default Pointy snorkel removal
Hi,
Has anybody ever removed the snorkal from the front of the airbox on a pointy? I did mine yesterday and it certainly seemed to go a little better, but that could just have been the huge noise coming from under the tank
Tapemonkey.
Old 27-02-07, 11:24 AM   #2
thor
Default Re: Pointy snorkel removal
yup!
replaced it with a snorkel from a sv1000 - straight swap, but bigger.
Old 27-02-07, 11:34 AM   #3
FG1
What are the pro's and con's of removing/replacing the snorkel ???
Old 27-02-07, 11:43 AM   #4
Mr Toad
Pro's
More air into the engine, so in theory a bit more power out of it
More induction noise (if you like that sort of thing)
Engine shouldn't need re-mapping, although if you have an aftermarket exhaust it might be a good idea - mine used to 'cough' a bit around town when coming off the throttle at the lights
Con's
More induction noise (if you don't like that sort of thing)
On a naked, the filter can be a bit exposed to the elements, especially if you've raised the tank a bit
The snorkle is easy to take out, and can easily be refitted. Give it a go
Old 27-02-07, 11:45 AM   #5
Cloggsy
I removed the snorkle on mine and put some mesh accross the gap to stop any big debris disappearing down there, then fitted a K&N filter & it worked great without the need of a re-map
Old 27-02-07, 11:46 AM   #6
FG1
Think I will. I have a Scorpion without baffles on mine, will the fuelling be affected much??
Old 27-02-07, 11:59 AM   #7
Sideshow#36
Did exactly the same and also fited 8mm tank raisers to allow even more through. I have remapped mine with a PCIII USB just to sort out the air/fuel mixture due to the snorkel removal, tank raisers, k&n and the full micron system. Sounds awesome and power matches the sound!!!! Next im either thinking about removing the airbox lid totally or doing a sort of forced air jobbie with vaccum cleaner hoses like on the old ZXR's.....
Old 27-02-07, 12:03 PM   #8
thor
I had mine remapped as I have a full system. Much smoother and flatter torque curve. That plus a throttle balance totally transformed the bike!
Old 27-02-07, 12:18 PM   #9
FG1
Well, I've taken the snorkel off and it does sound a tad better whilst in the garden. Looking forward to taking out for a spin to see what the noticable difference is....
Old 27-02-07, 12:25 PM   #10
DanF
Tried removing mine but seemed to loose a bit of low-mid power so I've put it back on. The bikes currently running a full micron race beta with a std map so I think it made it run slightly lean. I'm going to do the 5 degree advance, iridium plugs, TPS, snorkel and tank raise then take it to get a balance and remap.
Tank Raisers & De-snorkel: Pointy sauluk SV Talk, Tuning & Tweaking 8 18-05-09 11:41 PM
Anyone got Removal/fitting instructions for upper fairing K3 Pointy? shorn SV Talk, Tuning & Tweaking 6 27-07-08 09:22 PM
removal of ignition switch mod for pointy? flymo Mini-Twins 8 17-03-08 12:19 AM
Tool Box Removal Pointy hoppy34 SV Talk, Tuning & Tweaking 11 14-09-07 06:11 AM
pointy sv grab rail removal mic_hull SV Talk, Tuning & Tweaking 10 16-04-06 09:43 AM
