Old 01-03-07, 12:53 PM   #1
Jeremy Dunn
Exclamation idleing...then cutting out
Hi there,
Am at my wits end...have broken down three times now and me / bike mechanics are scratching heads.
Basically bike idles fine when cold but when warmed up soon starts to stall if at lower than 3000 rpm and soon starts to lurch, back fire and eventually cut out.
So far mechanics have - cleaned carbs, replaced rear coil, replaced spark plugs, checked valves, cleaned jets, tested fuel, even swapped and tried another cdi unit.
Still no joy...anyone know a London based SV650 expert? Having said that don't know whether its electrical or engine related.
I love my sv and I'm determined to solve and ride again!
Old 01-03-07, 12:56 PM   #2
Baph
Default Re: idleing...then cutting out
Sticking choke cable?
Old 01-03-07, 01:01 PM   #3
jambo
jambo's Avatar
He's got a point. The choke cables on the 99-02 SVs are a bit of a problem area, take them off the carbs if you can and clean them up, make sure it's moving smoothly and re-grease the cable. Water tends to run down inside the cable and corrode it at the front carb so it stick on. Do a search I'm sure someone else has put it better than me.
Check the simple stuff. Why not pop down to Frith St, Soho, on Friday evening and say hello? Many knowledgeable types there!
Old 01-03-07, 01:08 PM   #4
Jeremy Dunn
When you next down Frith Street...and usually what time? Will dfeinetely make a point of saying hi? .I actually work a few doors away from Bar Italia!
Old 01-03-07, 01:59 PM   #5
jambo
jambo's Avatar
Soho massive details here:
http://forums.sv650.org/forumdisplay.php?f=115
But in short, Frith St outside Nero's (opposite Bar Italia)
First people are usually there from 6:30pm depending, every Friday. Bring the bike along I'm sure somone will have a thought.
A friend had a bike cut out when it got hot, turned out to be a problem with the wiring loom
Old 01-03-07, 04:42 PM   #6
embee
embee's Avatar
As the others say, my first guess is sticking choke plungers. It can be either the plungers themselves or the cables, usually where they meet the plungers.
Presumably the electrical side of things is generally OK, reg/rec not playing up?
embee is online now   Reply With Quote
Cutting Out FlyinCustard SV Talk, Tuning & Tweaking 44 09-05-09 03:16 PM
My SV650SX keeps cutting out Majahid SV Talk, Tuning & Tweaking 4 24-06-08 12:11 PM
Cutting out.. MidgetMoose SV Talk, Tuning & Tweaking 4 25-11-06 06:22 PM
cutting out 01 sv650s SV Talk, Tuning & Tweaking 2 04-11-06 11:13 PM
Cutting out The Basket SV Talk, Tuning & Tweaking 1 19-03-06 08:46 PM
