Old 10-03-07, 07:19 PM   #1
hovis
Default scottoiler setting ?(flow rate ?)
got my scottoiler set to NO. 1 but the oil is coming out 1 drip every 5 seconds, any ideas?
Old 10-03-07, 07:29 PM   #2
BILLY
Default Re: scottoiler setting ?
Yeah remove it and lube your chain like normal people
Old 10-03-07, 07:29 PM   #3
rictus01
rictus01's Avatar
read the instructions
Cheers Mark.
Old 10-03-07, 07:30 PM   #4
hovis
got it off ebay.............. no instructions
Old 10-03-07, 07:32 PM   #5
rictus01
rictus01's Avatar
And no website ?
Old 10-03-07, 09:21 PM   #6
Stingo
Stingo's Avatar
Default Re: scottoiler setting ?(flow rate ?)
Is it brand new or second hand? If it's new, and there's a problem, you should be able to refer back to the 'dealer' or 'seller' - spose you could always email scottoiler.
Twitter: @poseidon_ashore
Old 10-03-07, 09:25 PM   #7
andyaikido
That flow rate is way too fast, and probably dangerous.
Scottoiler suggest 2 drips per minute but I found this to be too much.
I started at 2 drips p/min and kept turning it down untill there was only a little bit of oil splatter on the rear wheel.
Old 10-03-07, 09:32 PM   #8
hovis
second hand off ebay
Old 11-03-07, 09:54 AM   #9
Jabba
Hovi5,
Scottoiler say 1 - 2 dpm..... say 1.5dpm, so that's one drip every 40 secs.
Are you using "proper" Scotoil? The current colour is blue but there may be some peeps with an old bottle of the red stuff lurking about. They do a red oil but that is for use in high temp places.
Where have you mounted your reservoir? If it's too close to the engine or in a warm airflow then the viscosity will reduce and flow too quickly.
Strange that it should be flowing too fast - hope the internals of the reservoir are okay, not that there's much to go wrong. Does the oil flow stop when the engine stops?
Old 11-03-07, 10:37 AM   #10
Beenz
Originally Posted by Jabba View Post
Hovi5,
.... so that's one drip Borne every 40 secs.
If its not dripping when the engine stops, this sounds like either the oil that you are using is way too thin (as Jabba stated) or that the oiler is out of whack. I had one go too slow and sent it to Scottoiler (with proof of purchase) who adjusted it and returned it in four days, that was only a couple of weeks old though and purchased from new. I dunno what they would charge for an old unit to be fixed if its not had the correct oil used.
Good Luck!
Suspension flow chart lukemillar Bikes - Talk & Issues 18 20-08-08 06:09 PM
Injector flow wojto Bikes - Talk & Issues 0 26-01-08 09:05 AM
HI FLOW oil filter Smudge Bikes - Talk & Issues 8 24-09-07 09:30 AM
Free Flow Exhausts silver surfer Exhausts 2 14-06-07 02:38 PM
scottoiler setting? hovis SV Talk, Tuning & Tweaking 6 25-01-07 07:47 PM
