Old 11-03-07, 04:53 PM   #1
Tiger 55
Default Silverline Impact Driver (Stoopid question alert)
Anybody got one of these or similar?
Works in both directions they say but, um, how?
Got to be something to do with that sliding collar thingmy but just thought I'd ask before I did some trial and error testing...
Oh and the general idea is you apply the pointy end to the screw and batter the blunt end with a hammer, isn't it?
Old 11-03-07, 04:56 PM   #2
timwilky
timwilky's Avatar
Default Re: Silverline Impact Drive (Stoopid question alert)
Yes, set the direction, then belt the blunt end with a big hammer as you attempt to turn it as if its was a normal screwdriver.
Messing about with a small hammer will do nothing. you really do need to have a couple of lb and heavy blows.
Not Grumpy, opinionated.
Old 11-03-07, 07:36 PM   #3
jim@55
it looks like a standard impact 'driver ' al,,,,as said by tw.turn the collar(remember 'tighty righty ,loosy lefty)so basically anti clockwise to loosen something ,and clockwise to tighten something and then hit the end with a big hammer while turning and applying pressure ,bobs yer maws auntie ,btw they work a treat ive never known anything not to b loosened with one of them
Old 11-03-07, 07:38 PM   #4
Though do be careful, it's quite easy to damage other stuff when using them, ie, knock lugs off the swingarm as someone here did (I think). Very handy tools.
Old 11-03-07, 08:38 PM   #5
Tiger 55
Aha! I thought the collar just slid up and down and that didn't seem to do much, hence the stoopid question. I'll try turning it when I get in from work and see what that achieves...
Thanks all
Old 12-03-07, 10:23 AM   #6
Tiger 55
Well that achieves **** all! No, the collar thing just spins, it has no effect on the direction of drive. What am I doing wrong folks?
Or is it knackered?
Old 12-03-07, 10:49 AM   #7
timwilky
timwilky's Avatar
unfortunately mine is not a silverline one so I cannot be make/model specific.
My impact driver has a R<--->L indication on the black bit end. To set the direction you push in and turn the bit end. This then sets the direction of rotation if you were to push down on the driver
Old 12-03-07, 12:16 PM   #8
monkey
He he he. Bob's your great Aunt!
Old 12-03-07, 01:16 PM   #9
Tiger 55
God damn it you're a genius! Thanks Tim.
So what the heckety heck is the silver turny turny collar bit for?
Old 12-03-07, 01:48 PM   #10
Torn-Thorax
Supid answer. Did it come with a users guide?
Speedo Drive Question NedSVS SV Talk, Tuning & Tweaking 0 01-03-07 08:04 PM
**Boring Question Alert** Rider Idle Banter 33 04-08-06 08:21 AM
IT help - hard drive question will Idle Banter 7 25-05-06 06:42 PM
pc hard drive question will Idle Banter 6 15-05-06 02:38 PM
speedo drive question ? dangerous bri SV Talk, Tuning & Tweaking 2 04-04-06 02:14 AM
