Old 12-03-07, 01:09 AM   #1
Grinch
Thumbs down Complete Electrical Failure.
And when I say complete, I mean complete (for about 5-15 minutes)... having just got in from pushing the bike alot of the way home.
Its a strange one this... and Helga is not a happy SV, so.
Riding along all happy as Larry, when it all goes mental. Lights flashing on a off, clocks wizzing back and forth, oil and temp lights a flashing. Then it stops... then starts doing it again, bike coughs and dies. Ignition on but nothing, nada.
So I sit there... odd, I thinks, turns everything off. Turns on ignition, all comes on. Starts bike, puts on lights, pulls away and gets five yards before it all fails. Tries again but this time I get no where.
Pulls seat off checks fuses, contacts, loose connections, and disconnects heated grips. But nothing... then suddenly she's back. Travels a mile and it all goes mental again. This seems to repeat, then I suss it... When I put main beam on or try to flash the passing light it all pops.
So as you can imagine I'm confused, managed to get most of the way home in the dark with my side light on, traveling in illuminated areas. Give the lights on more try just on the final road home, pop it all fails again. So pushing it I is while trying the ignition all the way, funny enough it don't light up again till I push it on the drive!
So anyone got any good pointer for places to look, I'm going to be a busy boy tomorrow by the looks of it and I was hopping to get sorted round the house tomorrow as PJ and Jax is home Tues.
Old 12-03-07, 01:19 AM   #2
Default Re: Complete Electrical Failure.
Well, funny enough, I had the exact same thing- that turned out to be a loose main fuse! Not that that's likely for yourself but it's going to be something along those lines I reckon, something actually coming disconnected. I'd still check the usual wiring chafe spots for shorts, but they'd usually just kill it, not be intermittant.
And obviously make sure the fuse is good, it might have blown off the back of your troubles...
Old 12-03-07, 01:27 AM   #3
Grinch
Main fuse... ain't that down the side somewhere, as the ones under the seat are all fine and dandy.
Old 12-03-07, 01:30 AM   #4
rictus01
rictus01's Avatar
Yeah I'd go with what Andy said, you might alsohave a look at high tention arcing or (and I had one of these) the main control box plug needing pushing back on
Old 12-03-07, 01:34 AM   #5
Grinch
Ok, I'll try to find these things... now where did I put my manual again?
Old 12-03-07, 01:35 AM   #6
Yeah, it's in the wee green box just below the battery on the right hand side. It's in a bit of an awkward place, really, helps if you have nice ladyhands like mine
Old 12-03-07, 01:38 AM   #7
rictus01
rictus01's Avatar
How do you get the manual in there
Old 12-03-07, 01:59 AM   #8
21QUEST
21QUEST's Avatar
Good advice so far but might be your rectifier. I'll say check the battery is leads are secure then test the rectifier.
Ben
Nemo me impune lacessit.
Old 12-03-07, 09:53 AM   #9
ive had this sort of problem with a car and it was a snapped main earth cable.
Old 12-03-07, 10:54 AM   #10
Viney
One of the main chaffing points is on the rear subframe. Pop the rear end off and check where the wires wind round the subframe.
Complete Electrical Failure kbh SV Talk, Tuning & Tweaking 34 07-08-11 05:38 PM
Complete Electrial Failure :( OxY SV Talk, Tuning & Tweaking 3 05-04-09 01:56 PM
MOT Failure melody Idle Banter 33 24-02-09 03:06 PM
Electrical failure lookskyward1 SV Talk, Tuning & Tweaking 2 13-02-08 11:51 AM
Electrical System Failure Torn-Thorax SV Talk, Tuning & Tweaking 3 01-08-06 10:07 PM
