Hi
I have a 2001 Curvy, all runs smoothly at the mo Can anyone tell me what i should expect from my 11.5K service, whats to be done, how much are people paying for it etc? Bit wary of being ripped off by the guys in South West London ! Cheers H |
I paid £175 for my 11k service.
For that (from what I remember), I got the following: Oil/Air filter (didn't need an air filter, but was checked) Oil dropped & replaced. Brakes stripped, cleaned & put back together & bled (obviously). Chain & sprockets fitted (I'd bought them seperately, for £104 ish) Linkage stripped, cleaned & greased. Forks out & oil changed. Throttle body sync & timing. TPS adjustment. Clutch adjustment. There was probably more to it as well, and it didn't need all that, but that's what it got done. Services from now on are to be mostly done by me ![]() |
The 11.5K service should inclide:
Replace the air filter check spark plugs check the fuel hoses, PAIR and EVAP system hoses, and fuel components Change engine, transmission oil and oil filter. check and adjust idle speed check throtle/choke cable operation and free play check clutch operation check the cooling system check drive chain for wear and stretch check brake pads for wear check the operation of the breaking system check the tyre and wheele condition and tread depth check the tightness of all nuts and bolts check and lubricate the sidestand,lever pivots and cables |
basically a lot of checks and adjustments you can do yourself!! If you are competent enough to do the required replacements yourself then you can save a fortune.
cheers all
what do i need for a DIY service? | chompy | SV Talk, Tuning & Tweaking | 20 | 04-03-09 11:18 PM |
Service my SV | ukrobuk | Bikes - Talk & Issues | 1 | 19-02-08 08:59 PM |
Citizens Service - the new National Service. | grh1904 | Idle Banter | 11 | 06-09-07 11:44 AM |
Service Manual for SV650S 2001 and Service Recommendation | stone | SV Talk, Tuning & Tweaking | 1 | 09-05-07 04:20 PM |
first service | macdo | Pennine Massive | 5 | 09-09-05 06:45 AM |
