Old 23-03-07, 10:26 PM   #1
Born again
Default Fork upgrade
I have read a lot on this site about upgrading the fork springs and oil.
I can understand that this mod can help to stop dive for track and fast road riding, but does this mod make a significant difference to the bike in normal (whatever that is) road riding, if so how is the improvment noticed.
I ask because after returning to riding after a long layoff the SV is far better than the old bikes I used to ride, and I have not had the pleasure of riding the likes of a K7-gsxr so I cannot compare a modern sports bike suspension with the SV.
Old 24-03-07, 12:50 PM   #2
Born again
Default Re: Fork upgrade
Bump.................
Old 24-03-07, 12:59 PM   #3
socommk23
i done the springs and oil! generally made the bike handle better, dive less. better feed back through the bars and well worth it i think!
Old 24-03-07, 01:45 PM   #4
jambo
jambo's Avatar
The springs in an SV's forks are generally agreed to be about right for somone of 9-10 stone, if you're significantly more than that you should find stiffer springs stop the front from bottoming out or using quite so much of the suspension travel during riding. If the fork oil is past it's best, you will tend to find the front end feels rather vauge in corners and such, changing it with the fork springs should make the front end feel a bit nicer.
If you do a search it's been covered a few times before and other people will have explained better than me.
in short if you're happy with it as it is it can't be that bad, many people want the front end to be more composed under hard and fast riding conditions and this is where using the forks off other bikes such as GSXRs starts being suggested, but I'd doubt you'd be after that if you're happy how it is now
Old 24-03-07, 02:53 PM   #5
Stig
I'd say the same as Jambo. Changing the springs does make a difference. Even if you do not think that the front end is limited now, changing the springs and oil and you will then realise that indeed it was not brilliant before.
Changing the oil to a heavier cleaner oil will also help with the damping and make the steering feel more controlled.
I'd say it's the one best mod that you can make to the SV. That and a new rear shock.
Old 24-03-07, 03:27 PM   #6
ejohnh
Hi,
(2003 registered sv650 K1 curvy)
I'm 13 stone and to coin a phrase "my front end is crap". are you talking about Ohlin springs? Are they difficult to fit?
Old 24-03-07, 03:33 PM   #7
petevtwin650
Not difficult, just time comsuming.
You need to take the fork legs off to change the oil, which you might as well do otherwise you'd be wasting your money on the springs.
Ohlins,Progressive or Racetech springs plus thicker oil.
Old 24-03-07, 04:00 PM   #8
Stig
There are two different type of springs that you can have. Linear and progressive. They give two different qualities to heavy braking.
Further, changing the wieght of the oil also makes a difference as previously explained.
There are several different companies out there that you can use. I have Hagon linear springs. I phoned them up, gave them the bike details, my weight along with my riding style and the types of road that I will be using my bike on. With all this information they will be able to supply you with the correct springs, spacers and oil for your requirements.
So long as you have a manual and a means of lifting the front end off the ground, you should be able to change the springs and oil yourself. The most important part of the change is to make sure that you get the air gap correct and level in both forks. I would expect it to take you three hours or so if you have never done it before. Once you have done it once I'm sure you could get it down to an hour.
Old 24-03-07, 04:55 PM   #9
I used the Ohlins ones, because they're easy to find, but they only do one spring rate- or, at least, most Ohlins dealers can only get one. Racetech, Sonic, Hagon, etc etc, can all do different rates, so you can get the right ones for you instead of compromising. As it happens, the Ohlins were spot on for me so that was fine.
It's a great mod... Reasonably cheap, pretty DIYable, totally reversible... And other than the oil you can get most of your money back on resale if you choose to upgrade further or you sell the bike. Plus, if you decide to upgrade further to emulators then you can keep the same springs. And it does make a real world difference. Don't expect too much, you still have basic suspension afterwards, but it's basic, appropriate suspension at least. I reckon everyone over about 12 stone could benefit from it, myself.
Old 24-03-07, 05:07 PM   #10
Stig
I reckon everyone would benefit from it fullstop.
Fork Upgrade gazza SV Talk, Tuning & Tweaking 3 19-01-08 04:55 PM
Fork spring upgrade Mark_h SV Talk, Tuning & Tweaking 6 25-07-07 08:32 PM
GSX-R fork upgrade pics. Dan_SV Photos 11 30-05-06 07:36 AM
Fork Upgrade TSM SV Talk, Tuning & Tweaking 7 13-07-05 11:42 PM
Front fork upgrade Shooter SV Talk, Tuning & Tweaking 15 17-10-04 08:36 PM
