Old 26-03-07, 05:07 PM   #1
jonnygman
Default sv650sy / micron exhaust
Hi there im new to the forum i would like to ask anyone who knows if you need to re jet your carbs after putting on a full micron exhaust bike seems to be running fine but im not sure if i dont change the jets if it will do damage
Old 26-03-07, 05:11 PM   #2
hovis
Default Re: sv650sy / micron exhaust
no it will be ok
wlcome to the madhouse
Old 26-03-07, 05:22 PM   #3
jambo
jambo's Avatar
Micron do several types of system, for a slip on can I wouldn't bother but I can't seem to find details of the full systems they do for the SV. A dyno run with Air / Fuel sensor would only be about 20-30 quid anyway. Hopefully someone else knows the score better than me.
Edit: http://news.micronexhaust.com/newproducts.php/22 While this is a full system for a K3 onwards, it doesn't say "no need to re-map" which is common if this is the case, Was it fitted by a garage or yourself?
Old 26-03-07, 05:28 PM   #4
jonnygman
cheers lads looks like a good site you have here thanks for the advice
Old 26-03-07, 05:35 PM   #5
jonnygman
i fitted it myself on to a 2000 plate sv650s as i said seems to be goin ok
Old 26-03-07, 07:20 PM   #6
rictus01
rictus01's Avatar
Normally a full system will get you a few more ponies, as it is less restrictive, In order to gain this advantage, you will need to change the air filter, with both of these changed, retaining standard jets will lead to a weaker mixture and the topend being hotter.
In short, if you haven't changed the air filter, you're not going to get the full benefit from it, and if you have, you'll need to re-jet before you do any harm.
Cheers Mark.
Old 26-03-07, 08:11 PM   #7
jonnygman
i have changed the filter to a bmc filter how will i know if its running lean
Old 26-03-07, 08:45 PM   #8
rictus01
rictus01's Avatar
Just as a matter of interest, which BMC filter the Race or RS race ?
As you've made the air flow greater but kept the fuel flow the same (standard jets) it will now be running lean (greater volume of air to fuel).
the plugs will be whiter and the engine topend hotter (good pictorial guide on the back of most of the haynes manuals), or in the longer term it'll destroy itself, both will tell you.
Cheers Mark.
Old 26-03-07, 10:31 PM   #9
jonnygman
Cheers Mark.
i fitted the race bmc filter the only thing is i am now unsure if the pipes are race or just the replacement type with the micron can (no baffles) on the back, the bike revs freely all the way up to the top off the rev range no flat spots and it pulls very well
Old 26-03-07, 10:35 PM   #10
svrash
I'm running 160s with my micron system and BMC race RS
Micron Exhaust. Should I ? Grant66 SV Talk, Tuning & Tweaking 7 31-07-08 10:50 PM
Micron Exhaust Pics Miles SV Talk, Tuning & Tweaking 8 28-06-08 08:51 PM
Bracket for Micron exhaust Dreas SV Talk, Tuning & Tweaking 7 27-03-07 01:39 PM
Micron Exhaust Pics? Cam_73 Exhausts 1 14-05-06 06:36 PM
MICRON EXHAUST FOR SALE Flurby Jim For Sale - SV's and SV related items 1 12-01-06 09:19 AM
