Old 27-03-07, 08:49 AM   #1
hovis
Default spark plug socket size?
please can you tell me what size socket i need to remove the spark plugs?
Old 27-03-07, 08:57 AM   #2
Baph
Default Re: spark plug socket size?
Use the socket in the toolkit
Old 27-03-07, 08:59 AM   #3
TSM
The Sick Man
TSM's Avatar
If you still have the tool kit from the SV there is a hinged tool & extension bar that is used to remove the spark plugs. If not, i cant remember as i have two spark plug tools and only 1 fits, which is good enough for me.
Old 27-03-07, 08:59 AM   #4
Viney
Its the smaller of the 2. 17mm (I may be wrong, it may be 19mm, but there are only 2 sizes of plugs, and its the smaller)
Old 27-03-07, 09:03 AM   #5
hovis
i have not got a tool kit im putting 1 together i have 3 spark plug sockets in my socket set, but cant remember which one it is, i could remove tank & check, but thought i would ask the org first
Old 27-03-07, 09:04 AM   #6
Baph
Surely it's easier to swing the radiator out of the way & check on the front, rather than lift the tank & check the back spark plug?
Old 27-03-07, 09:05 AM   #7
TSM
The Sick Man
TSM's Avatar
16,19,21 it seems
http://www.spark-plugs.co.uk/pages/p...ance_tools.htm
SV will be 16 as its a NGK C type plug.
ps. I still may be wrong. Dont think so though.
Old 27-03-07, 09:07 AM   #8
hovis
ARE YOU AVIN A LARF
its eaiser to win the lottery twice on a sunday to get to the front plug
16mm thanx
Old 27-03-07, 09:10 AM   #9
Baph
ARE YOU AVIN A LARF
Not at all.
Single bolt to allow you to swing the radiator forwards, then you've got access to the front plug. (Well, it is on my bike)
Or if you want to do 2 allen bolts, then prop the tank up, then check the rear plug (but be careful of stones falling in the hole if you take the plug out! Right pain that is!) Then reverse to put it back together, all to check the size of the socket.
I reckon I could check & get the bike back together by the time you had your tank propped up
Old 27-03-07, 09:27 AM   #10
hovis
Not at all.
you forgot to remove side panels & seat to lift tank
what size socket? kwak zzr SV Talk, Tuning & Tweaking 13 10-05-09 07:16 PM
what size socket? larigos SV Talk, Tuning & Tweaking 6 30-03-09 12:17 PM
HELP! spark plug problem heedbaw SV Talk, Tuning & Tweaking 7 23-10-07 02:36 PM
What size socket cuffy SV Talk, Tuning & Tweaking 4 19-07-06 01:27 PM
What size socket do I need ?(Urgent) PoRk ChOp SV Talk, Tuning & Tweaking 4 20-01-05 03:35 PM
