Old 28-03-07, 06:42 PM   #1
socommk23
Default forking forks
left hand seal has just suddenly gone today and letting oil out.
i thought i could sort it out with some new seals but have found that on the leg there is a ridge...or kink...exesive wear on the back of the left fork
stanchon only (the one leaking).
could this be the reason for the sudden leak?
or can a seal alone sort it out?:O
anyone have a left hand stanchon going cheap if its a case of replacing it? (97 tl1000s)
all help will be great right now as weather getting better for riding and i need to get out.
cheers guys.:cheers
Old 28-03-07, 07:11 PM   #2
Stig
Default Re: forking forks
From your description it would appear that the fork is bent or at least the has been damaged before which has caused the issue that you have now. I would think about having the forks checked out properly to see if they are indeed not straight.
forking around again! Caddy2000 SV Talk, Tuning & Tweaking 5 03-04-08 06:11 PM
Another forking question. BigBaddad SV Talk, Tuning & Tweaking 7 23-04-07 06:44 PM
Forking Question. Jester666 SV Talk, Tuning & Tweaking 1 15-08-06 10:01 AM
Forking resolve? Blue_SV650S SV Talk, Tuning & Tweaking 11 17-07-06 10:47 AM
Forking dilemma. Blue_SV650S SV Talk, Tuning & Tweaking 39 12-07-06 05:58 PM
