Old 28-03-07, 09:33 PM   #1
greenzombie
Exclamation coolant in sump oil
Hi
CAN ANYONE EXPLAIN WHY I HAVE GOT COOLANT IN MY SUMP OIL, OR TELL ME WHERE IT IS LIKELY TO BE COMING FROM? NO STEAM IN EXHAUST SO I ASSUME IT'S NOT GETTING IN TO THE CYLINDERS.... CHEERS
Old 28-03-07, 09:49 PM   #2
Dan
Default Re: coolant in sump oil
Welcome to the madhouse!
Could be just condensation. Has the bike been standing for a while?
My ZX-7R has a fine condensation mist on the oil window after a week or so standing, and my pointy SV did the same.
oh, and BTW, please turn off the CAPS LOCK!
Old 28-03-07, 09:58 PM   #3
embee
embee's Avatar
someone posted that they had the core plugs pop out in the cylinder head, as shown here
Old 28-03-07, 10:03 PM   #4
ejohnh
Originally Posted by greenzombie View Post
Hi
There was a thread about this a while back, I always think of a blown head gasket when I hear of coolant in the sump.
Old 28-03-07, 10:10 PM   #5
ridelikeaturtle
How much coolant? A guy here in ireland had a freeze plug go and it put coolant directly into his sump (in a TL1000S) -- so this could be the same sort of thing.
Old 28-03-07, 10:59 PM   #6
CB1ROCKET
what are we actually looking for in the photo?
Old 29-03-07, 07:15 AM   #7
Dan
Centre section of the photo between the two cam covers, you'll notice the two round core plugs which are sitting over the holes they should be... well... plugging.
Old 29-03-07, 04:47 PM   #8
CB1ROCKET
Cheers, obviosuly they would of been rattling about, so I assume we would of hear something from the top end?
Old 29-03-07, 04:58 PM   #9
SV650Racer
The core plugs dont normally go if there is coolant in the system though.
Old 29-03-07, 05:38 PM   #10
Biker Biggles
Biker Biggles's Avatar
How much coolant?Is the level in the rad dropping noticeably and the "oil" level rising with the water in it?Does the bike run OK?If the levels are not changing,and it runs OK I would suggest it's condensation as stated above and a good long run will burn it off.If it's not that good luck fixing it.
Oil Sump washers. Baph Bikes - Talk & Issues 4 06-05-09 08:28 PM
Sump washer TightRS SV Talk, Tuning & Tweaking 3 18-04-09 09:56 PM
Sump plug bolt Jimbo_Bimbo SV Talk, Tuning & Tweaking 28 04-09-08 12:42 AM
Oil Sump Bolt BazJ27 SV Talk, Tuning & Tweaking 2 19-08-06 10:14 AM
Sump washer The Mass SV Talk, Tuning & Tweaking 14 27-06-06 09:53 AM
