Hi all, I bought my '99 sv650 last year and it was leaking a bit of oil from the clutch cover. So, I took off the clutch cover, it had been sealed with the standard o-ring and some black permatex. So, I threw away the o-ring and cleaned the whole thing up; then I filled the groove where the o-ring would be with black permatex and put the thing back on. That has held up pretty well for ~6 months, but now it seems to be leaking again...
So, what I'm thinking of doing is buying a sheet of cork gasket material and resealing the whole thing with permatex again.... I don't trust buying a new o-ring is going to fix this problem or I would have done that already. Has anyone tried this with any success or have any other recommendations on how to fix this problem permanently? thx Matt |
Okay, so I did this today, I'll report on findings as I found out how this works...
I bought a sheet of high-temp gasket material at the local auto parts store. Traced a pattern onto that using the clutch cover itself and cut that out. Then put high-temp black permatex on all the surfaces and put the whole thing together... Has to be better than what I had before. thx m |
Toe Guard + Rocker Cover Gasket | svdemon | For Sale - SV's and SV related items | 25 | 11-08-09 08:09 PM |
K3 clutch cover gasket | flymo | Stuff Wanted | 0 | 23-03-09 08:48 PM |
Clutch Cover | carsounds_dan | SV Talk, Tuning & Tweaking | 17 | 12-06-08 04:27 PM |
Clutch cover. | scottjames | SV Talk, Tuning & Tweaking | 8 | 16-04-08 11:30 AM |
Outer clutch cover gasket on curvy | UKStreetFighter | Stuff Wanted | 6 | 08-03-07 02:38 PM |
