Anyone know a simple way of doing Pareto Charts in Excel to save me moving the dat back and forwards to Minitab?
Ta! |
Our works "idiot's guide to Excel charts" says this (note, I haven't used Excel in years):
Bl00dy Hell!!!!
Someone else who uses Minitab. Just a bit of overkill for Pareto charts though! I find that a Real Pareto chart is wasted on 80% of the audiance, I tend to use Excel to produce a bar chart with the bars sorted into decending order. I generally dont bother to convert actual numbers into percentages (people only convert it back in their heads anyway - and get it wrong!) and I omit the percentage line. The method I use to do this (Its not the most efficient but it is easy to do) 1. Copy the catagoris and the occcurances ito two consectuive columns 2. Select the data in the two columns 3. Sort the data in decending order on the occurances column 4. click the chart Icon 5. Select the bar chart 6. Add titles etc 7. Job done. I know its not a proper pareto but it does what I want and its quick! HTH Chris |
#5 | |||
I'll knock one off using your suggestion though and see if I can get away with it Quote:
![]() ![]() Cheers both |
Excel | Graciepants | Idle Banter | 15 | 31-03-09 10:52 PM |
OK Windoze guru's (Excel Question) | timwilky | Idle Banter | 7 | 23-10-07 11:57 AM |
Another one for the Excel gurus | Jelster | Idle Banter | 6 | 12-06-07 08:48 AM |
Quick excel question if some1 can help | Jimmy2Feet | Idle Banter | 4 | 21-11-06 03:27 PM |
Excel question | nickj | Idle Banter | 3 | 04-09-06 12:35 PM |
