Old 13-04-07, 10:53 PM   #1
svrash
Default Micron delta+ can help
I've got my self a delta+ can with removeable baffle but the baffle is stuck solid I've stripped the can ready for a stubby job on it and cant see any reason for it to be stuck (I've removed the rivet)
Its doing my head in!!
Old 13-04-07, 10:58 PM   #2
sv650nutter149
Default Re: Micron delta+ can help
its got silocan sealent in it mate just get pliers and yank it out
Old 13-04-07, 10:59 PM   #3
svrash
I've heated it, hit it with a hammer and the fecker still won't come out
Old 14-04-07, 12:13 AM   #4
21QUEST
21QUEST's Avatar
That's because the delta+ cans(earlier ones at least) are not designed to be easily removeable
Ben
Nemo me impune lacessit.
Old 14-04-07, 07:51 AM   #5
you have to remove the end cap and grind off a weld to adapt the can to make it removable, its been done to both mine.
Old 14-04-07, 08:37 AM   #6
tbh i wouldnt bother, the baffles on the delta + are only tubes with no resistance anyhow so i just leave mine in, it makes little or no diff to the sound if they are in or out.
Old 14-04-07, 08:41 AM   #7
svrash
That makes sence I've aready broken one weld trying to get the baffle out
Old 14-04-07, 10:21 AM   #8
Rich
Rich's Avatar
I've got a delta plus you can remove the baffle easy..
1) undo the baffle screw holding it to exhaust
2) Push baffle inside can as far as you can
3) look up inside the top of the exhaust and just inside is a bolt holding the end of the can on
4) undo with an allen key, take off the end of the exhaust (the whole end of it)
5) pull out baffle, replace the end making sure not to trap the exhausts packing. Can be abit fiddley but you can do it!!
6) ENJOY!!!
Hope that helps you!!!
RIP Hovis - Unlucky Boyo
Old 14-04-07, 11:26 AM   #9
svrash
I done it i had to file down 3 welds that held the baffle to the end cap
The baffle was welded to the 3 prong bracket so no wonder it didn't want to come out
Old 14-04-07, 03:58 PM   #10
the new delta + cans are made so they do come out.
db killer for 99-03 micron delta+ Ping Stuff Wanted 7 04-05-09 11:36 AM
micron delta + baffle kwak zzr For Sale - SV's and SV related items 2 07-06-07 05:44 PM
re packing a micron delta + can? how to and what to use? kwak zzr Bikes - Talk & Issues 9 16-03-07 01:03 PM
Micron Delta+ Slip On For 03-> fubber Exhausts 0 28-11-05 11:29 AM
Micron Amanda M Exhausts 4 05-09-04 10:58 PM
