Old 15-04-07, 06:11 PM   #1
jonnygman
Default crappy brakes
having probs with front brakes recently took it to my mechanic he said the pistons in the calipers were shagged and to get anodised ones made or someone who supplies of the shelf any ideas as where to get these also a seal kit as well
Old 15-04-07, 07:20 PM   #2
riktherider
Default Re: crappy brakes
all you really need to do is to get a pistonseal kit and the pistons for the front. Annodised?? never heard of them personally. once i got mine changed they worked very well. i also changed the hoses at the same time. i believe the whole piston and seal kit was around 56 quid from cresent suzuki. fitted them myself so saved a lot more. that should de the trick
rik
Old 15-04-07, 09:08 PM   #3
haggis
Try shop.wemoto.com
Old 15-04-07, 09:22 PM   #4
Biker Biggles
Biker Biggles's Avatar
How old is your bike?It may be worth thinking about replacing the calipers with a used set off a newer crashed bike.Saves a lot of messing about and can be cheaper if you shop around.Old calipers can be rebuilt,but if the bores are scratched they soon go again.
Old 15-04-07, 09:43 PM   #5
haggis
Interested as i'm doing mine just now.
Is £42 a fair price for dust and oil seals, front and rear?
Old 16-04-07, 12:31 AM   #6
jonnygman
cheers lads do you know if any six [pot calipers fit on without mucking about
Old 16-04-07, 08:56 AM   #7
You could get adaptor plates to run GSXR 6-pots, but it'd be a bit rubbish... It'd add a load of weight, and the SV forks are probably as much of a limit on braking as the calipers are. If you want to swap calipers, use the 4-pots not 6, they're better in the real world as well as cheaper and lighter.
But tbh the best braking upgrade you can do is to just look after them- if your current ones are damaged to the point where they need new pistons then they've been neglected, GSXR ones would go the same way soon enough if treated the same. Do you ride in winter? Salt buildup's the number one brake killer. Decent pads- something like Carbon Lorraine A3+... The SV brakes, when they're in good condition, are actually pretty good. An R6 master cylinder (the recent 16mm Brembo) is a top upgrade and not too pricey, around £40 usually.
Old 16-04-07, 10:01 AM   #8
21QUEST
21QUEST's Avatar
.....Decent pads- something like Carbon Lorraine A3+... The SV brakes, when they're in good condition, are actually pretty good. An R6 master cylinder (the recent 16mm Brembo) is a top upgrade and not too pricey, around £40 usually.
He is right you know
My SV calipers were rebuilt not too long again. Pistons were sticking on one side and the sliding bit was err....not sliding. The sliding part is probably over-looked by many during routine maintainance.
Anyhoos, with that done, two finger stoppies are achievable. I'm talking proper stoppies and not ickle ones. I don't even use fancy pads either.
Saying that if I do keep the bike, I'll be putting GSXR K1-K2 calipers on...when finally get round to having the brackets made . Easier to look after IMO.
Ben
Nemo me impune lacessit.
Old 16-04-07, 10:11 AM   #9
Yeah, I like the A3+s because they last pretty well and they work a bit better in the wet than the OE ones (at least in the GSXR calipers), but they don't give much away on outright power over the SBKs and HHs and suchlike and aren't stupidly bitey. Much more sensible road pad I reckon. Not cheap, mind
Old 16-04-07, 10:30 AM   #10
Alpinestarhero
Take them apart, give them a ruddy good clean, fit some braied hoses and new pads, and discs too if they are needed.
Then decide if you need to spend lotsa money!
Matt
Crappy snatchy throttle. stressed_myke SV Talk, Tuning & Tweaking 16 10-02-09 10:44 AM
suzuki seat cowl -crappy fit jonboy99 Bikes - Talk & Issues 14 29-04-07 09:53 PM
Cheapo Rubbish Crappy........(Alarm) danf1234 Bikes - Talk & Issues 27 25-04-07 08:42 PM
brakes sv650s_guy SV Talk, Tuning & Tweaking 9 16-02-06 07:43 PM
Brakes - Help! Yokel SV Talk, Tuning & Tweaking 7 11-04-05 08:17 PM
