Suits Post your own reviews, opinions and experiences on this subject.
Old 18-04-07, 06:46 PM   #1
svJvJ
Unhappy new leathers....Heeeeelp please
Hi all,
I bought some second hand HG leathers.....It's a bit of a sqeeeeze to get into them. Not sure wheather to keep of sell them on.
This is my first set of leathers and i'm not sure if its just cause its a completely different feel to the textiles or if i'm just a fat b*st*rd....Do they mould to your body shape?
I find them quite restrictive around the knees....lifting my legs(treestumps) seems quite an effort and I found after giving them a test ride tonight my riding was poor.....even down to swifting gears.....(not that I have major skills to start with)
Not sure, do I keep them and lose a few pounds, or sell them and get something a bit loose fitting.
This has been the last straw on the camels back after a very bad week or two at work so cracking open the booze now.....very depressed!!!!
Any advice greatly appreciated
Old 18-04-07, 07:02 PM   #2
K
Default Re: new leathers....Heeeeelp please
When you say 'second hand' - how worn/old are they already?
It maybe that they've already stretched as far as they are going to and you'd be better off with something else.
If they're fairly new then it could be worth perservering with them. Normally new leathers should be slightly on the tighter side of snug - they then break in to fit.
Old 18-04-07, 07:03 PM   #3
gettin2dizzy
they need to be pretty tight, if its loose it can grab your skin in an off. They will loosen up, there are some waxes you can get to speed it up. They're certainly more uncomfortable than leathers - but maybe incentive to lose a few pounds? could do it in a week!
Old 18-04-07, 07:04 PM   #4
gettin2dizzy
your always that bit quicker than me k dammit!
Old 18-04-07, 07:12 PM   #5
svJvJ
they look brand spanking .....the guy said he only wore them a couple of times sold as he was selling his bike and all gear......
thanks 4 the advice... .......Dr Atkins might hekp then....
Old 18-04-07, 07:17 PM   #6
Kate
Alternatively, get them adjusted? Mine just wouldn't break in at all so in the end I took them to Nine Lives in Farnborough and basically they just didn't fit me properly. I went back a week later to collect my adjusted leathers and they fit perfectly.
Old 18-04-07, 07:18 PM   #7
svJvJ
Ta....always a second option then if I cant shift the pounds......Is that expensive to do?
Old 18-04-07, 08:54 PM   #8
kitkat
just wear them around the house for a while. do hoovering with them on, lots of bending and stretching and they will loosen off a wee bit. they take a bit of getting used to but do stretch. plus you will get brownie points for doing housework
Old 18-04-07, 09:06 PM   #9
svJvJ
mmmmm, the mrs might get used to that , me doing housework in leather......sounds a bit to fetish'ish to me.....might to the garden, sounds a bit more manly......+ sweating it out in the sun might help with the extra pounds....or make my new leathers smell.......
Old 18-04-07, 09:08 PM   #10
kitkat
oh im sure your mrs will love it
new leathers. dirtsk8 Idle Banter 0 29-07-08 10:25 AM
Wiring phone extension - HEEEEELP 600+ Idle Banter 12 24-02-08 02:44 PM
New leathers, ( leathers advice and opinions ) John 675 Suits 19 19-03-07 09:24 PM
New enough leathers... philipMac Suits 4 17-01-06 07:04 PM
LEATHERS apoc76 Idle Banter 0 08-01-70 12:55 PM
