Hi this is my first post and first day on the sv forum and i have a problem!
The Sick Man
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
c29 - secondary throttle position sensor malfunction.
The workshop manuals which are linked on the home page of this site will give you more information, however it may well be something you're not going to be able to fix yourself. |
thanks for the info im going to find out how much part is
I think I've got the same problem.
Getting plugged in on saturday to determine problem |
scorpion, DIY. Stick a bit of wire in the Dealer Service Connector, turn ignition on, the bike will tell you the error code, then use the link provided by TSM.
If the "secondary fuel sensor" means the fuel cut off, that's 33960-06G10 & is located under the main rider seat. On my K6 it's behind the ECU & slightly to the right as you look at it. If you have to buy one, should be around £25. Simple plug it in to fit it, no tools required (once the seat is off). That's the only thing I can think of as a seconday fuel sensor on the pointy. Strange that the fuel cut would cause high revs, but still. |
Cheers Baph I might give it a go if I'm brave enough. I just have an awfull habit of f***ing up things like that
#9 |
Ta
#10 |
Thanks Baph I'll give it a go and let you know hoe I get on.
Call me stoopid but what is TPS adjustment, got a hangover and can't think too well at the mo. ![]() I think I might owe you a beer ![]() |
rattling noise at high revs. | sketti76 | Bikes - Talk & Issues | 3 | 10-05-09 11:16 PM |
Bike runs at high revs | lily | Bikes - Talk & Issues | 9 | 11-09-08 09:43 PM |
loosing power at high revs | riktherider | SV Talk, Tuning & Tweaking | 2 | 23-08-07 11:22 AM |
CCC High Level link pipe.... Bit High? | bobit69 | SV Talk, Tuning & Tweaking | 29 | 13-04-06 09:16 PM |
High street high side - pics added. | Wiltshire7 | Bikes - Talk & Issues | 91 | 20-04-05 06:50 PM |
