Old 19-04-07, 08:18 AM   #1
BigBaddad
Default Oil,Filters and Part numbers, Please.
Hi,
I have a slight oil leak from my clutch cover on my sv650s-y which I'm going to fix, so am gathering all the parts. I'll change the oil and filter at the same time.
I think I'll need the following parts,
Clutch cover O ring.
Sump Plug seal.
Oil filter.
Oil
Can anyone tell me the part numbers or sizes/types of ring and seal. Can you recommend a good filter and oil. And anything else I might need to consider.
Cheers.
Old 19-04-07, 08:28 AM   #2
petevtwin650
Default Re: Oil,Filters and Part numbers, Please.
Use this site to source the part numbers
http://www.alpha-sports.com/suzuki_parts.htm
Click on the year then your model
Use this site to check prices
http://www.robinsonsfoundry.co.uk/
click on the parts section in the on-line shop
I've been getting my oil and filter from Hein Gericke as they've been doing a deal that gives you 5ltrs of 10/40 semi, oilfilter and airfilter for £24.50. Bargain. However I believe they've stopped that deal now. Bu**er.
Old 19-04-07, 08:51 AM   #3
Baph
The last oil I put in the SV was 5w40 Castrol fully synth stuff (I'll have a look later for the exact type).
Why? Well, I needed oil. Halfords was the only shop open, and this was cheaper than 4 bottles of the 10w40 stuff (only had small bottles).
Technically it's more of a track use oil, but I figure I do high miles anyway. It's more expensive than the normal stuff I used, but I can certainly feel the difference (although, I accept I may be comparing old oil with new). £30.99 buys you 4L.
Oil filter, I got one from the local stealership. £12.something.
Old 19-04-07, 09:38 AM   #4
BigBaddad
Halfords doing there own 5/40 @ £16 and 10/40 @ £14 are they good enough.
£12.62 for an O ring
haynes manual part numbers riktherider SV Talk, Tuning & Tweaking 2 18-08-08 06:37 PM
Seat Part numbers Girth SV Talk, Tuning & Tweaking 2 25-10-07 08:26 PM
Part numbers BoltonSte SV Talk, Tuning & Tweaking 2 31-07-05 03:39 PM
Part Numbers bikerskez SV Talk, Tuning & Tweaking 10 01-04-05 04:08 PM
Part numbers database... markfc SV Talk, Tuning & Tweaking 1 11-03-05 05:53 PM
