Old 20-04-07, 11:12 PM   #1
stooster
Default personal bike setup
is there a guide somewhere on getting the bike setup well to suit the rider..
i have 2001 curvy and as its my first decent bike i dont know if its set up right or not....ie..suspension pre load...also heard that letting forks through yoke a little higher makes a big difference..
im 5'11 , 15.5 stone....any tips....
cheers
stu
Old 20-04-07, 11:26 PM   #2
weazelz
Default Re: personal bike setup
cheers
stu
search for "setting static sag" or similar - that should help you set the preload front & rear
if you want the bike to turn a bit quicker then consider dropping the yokes down the forks a little. again, search for details, it's been covered lots of times
Old 21-04-07, 01:13 AM   #3
rictus01
rictus01's Avatar
Indeed however on a 2001 you won't have preload adjusters on the forks, so will have to do it by spacer length, I'd look to change the springs if they haven't been already done at the same time, the rear doesn't have a lot of adjustment as standard, but fitting a SS bike shock is a good upgrade, generally unless you are shorter legged the penalties for dropping the forks threw is prohibative, a better solusion is to raise the rear (either longer shock or "dog bones").
Have at look at the racetech web site for a simplistic explanation of static sage.
But as suggested a search will turn up plenty of results.
Cheers Mark.
Old 21-04-07, 11:23 AM   #4
stooster
cheers fellas.....will do
Old 21-04-07, 05:37 PM   #5
when my mate put the deposit on his buell xb12r they took his height and weight and set the bike up just for him, apparently buell do this for all there customers.
Personal Accident Insurance - bike racing flymo Racing and Paddock Chat 25 04-03-10 06:03 PM
Making your own bike camera setup ala' Gp style! muzikill SV Talk, Tuning & Tweaking 15 17-05-07 06:33 PM
Pointy K3> twin can setup for 650, does 1000 setup fit? aposegil Stuff Wanted 3 26-10-06 03:41 PM
Any Personal Bike Reviews? Demonz Bikes - Talk & Issues 2 21-05-06 02:33 PM
my personal best - loading the bike Sarj Soho Massive 22 30-12-04 04:51 PM
