Old 25-04-07, 09:58 AM   #1
Grinch
Default R1 Battery
Right, tried searching but it appears I can't find it, seems to pick up every post with the word R1 or battery in it.
Was it the R1 or R6 battery thats been recomend as a alternative to fit in the SV if you have to trim your shock to fit, due to its much smaller size.
Old 25-04-07, 10:02 AM   #2
Baph
Default Re: R1 Battery
T'is the R1, like this.
Old 25-04-07, 10:17 AM   #3
Grinch
Lets see if I can get it cheaper on E-bay.
Is it smaller then?
Cranking Current 125Amps 12Volts 11Ah L151mm W70mm H130mm Weight 4.1Kg
mmmh.
Old 25-04-07, 10:20 AM   #4
Grinch
Right,
Battery Family: Maintenance Free Battery Type: YT12A-BS
Voltage: 12 Capacity: 9.5 Dimensions: 6" x 3.4375" x 4.1875" Weight: 6.3 lbs. Metric Dimensions: 150mm x 87mm x 105mm Metric Weight: 2.8 kg Polarity: Acid Volume: 0.5 Amps: 1 C.C.A.: 175
Old 25-04-07, 10:21 AM   #5
Baph
No idea about the size difference. But it does give a wee bit more juice (harder to crank an R1 obviously).
Least you've got somewhere to start now
Old 25-04-07, 10:22 AM   #6
Luckypants
Luckypants's Avatar
Is this actually neccessary? I just put my old battery back in with the fuses / relays on top like before. Battery was raised up on foam blocks to prevent it sitting on the shock's reservoir. Seat goes on no problemo, so what's the issue here?
Old 25-04-07, 10:22 AM   #7
Grinch
Err looks bigger then the SV one to me... Just wanted to make sure I had a nice easy fit.
I want it all perfect...
Old 25-04-07, 10:36 AM   #8
21QUEST
21QUEST's Avatar
...in that case a shock made specifically for the SV is what you need
Ben
Nemo me impune lacessit.
Old 25-04-07, 10:50 AM   #9
Grinch
Ben
Ok... ok...
Old 25-04-07, 04:32 PM   #10
use "and" in your search btw, only way to get good results from our search...
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
What battery? richie95 Bikes - Talk & Issues 11 15-06-08 08:35 AM
The Battery??? SV PILOT Bikes - Talk & Issues 8 30-03-08 10:06 PM
Battery woe seandixie SV Talk, Tuning & Tweaking 1 14-09-06 04:11 PM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
